Sony Handycam HDR-CX580V Recording Button Replacement
  1. Sony Handycam HDR-CX580V Recording Button Replacement, Battery: step 1, image 1 of 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
    Ask FixBot
  2. Sony Handycam HDR-CX580V Recording Button Replacement: step 2, image 1 of 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
    Ask FixBot
  3. Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: step 3, image 1 of 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: step 3, image 2 of 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: step 3, image 3 of 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
    Ask FixBot
  4. Sony Handycam HDR-CX580V Recording Button Replacement: step 4, image 1 of 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
    Ask FixBot
  5. Sony Handycam HDR-CX580V Recording Button Replacement: step 5, image 1 of 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
    Ask FixBot
  6. Sony Handycam HDR-CX580V Recording Button Replacement: step 6, image 1 of 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
    Ask FixBot
  7. Sony Handycam HDR-CX580V Recording Button Replacement: step 7, image 1 of 2 Sony Handycam HDR-CX580V Recording Button Replacement: step 7, image 2 of 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
    Ask FixBot
  8. Sony Handycam HDR-CX580V Recording Button Replacement: step 8, image 1 of 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
    Ask FixBot
  9. Sony Handycam HDR-CX580V Recording Button Replacement: step 9, image 1 of 3 Sony Handycam HDR-CX580V Recording Button Replacement: step 9, image 2 of 3 Sony Handycam HDR-CX580V Recording Button Replacement: step 9, image 3 of 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
    Ask FixBot
  10. Sony Handycam HDR-CX580V Recording Button Replacement: step 10, image 1 of 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
    Ask FixBot
  11. Sony Handycam HDR-CX580V Recording Button Replacement: step 11, image 1 of 1
    Tool used on this step:
    Buy
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
    Ask FixBot
  12. Sony Handycam HDR-CX580V Recording Button Replacement: step 12, image 1 of 2 Sony Handycam HDR-CX580V Recording Button Replacement: step 12, image 2 of 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
    Ask FixBot
  13. Sony Handycam HDR-CX580V Recording Button Replacement: step 13, image 1 of 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
    Ask FixBot
  14. Sony Handycam HDR-CX580V Recording Button Replacement: step 14, image 1 of 1
    • Carefully remove the metal frame from the top casing.
    Ask FixBot
  15. Sony Handycam HDR-CX580V Recording Button Replacement: step 15, image 1 of 1
    • You are now free to remove the recording button, as well as its connection strip.
    Ask FixBot
Derek Fritz
378 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 33
All Time: 914
