Sony Handycam HDR-CX380 Shutter Assembly Replacement
  1. Sony Handycam HDR-CX380 Shutter Assembly Replacement, Battery: step 1, image 1 of 1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
    Ask FixBot
  2. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 2, image 1 of 1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
    Ask FixBot
  3. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 3, image 1 of 2 Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 3, image 2 of 2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
    Ask FixBot
  4. Sony Handycam HDR-CX380 Shutter Assembly Replacement, Camera Shell: step 4, image 1 of 1
    • Orient the camera with the battery side facing up.
    Ask FixBot
  5. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 5, image 1 of 1
    • Remove the single 4.5 mm Phillips #00 screw.
    • Remove the single 5.5 mm Phillips #00 screw.
    Ask FixBot
  6. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 6, image 1 of 2 Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 6, image 2 of 2
    • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
    • Remove the casing using your right thumb and index finger.
    Ask FixBot
  7. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 7, image 1 of 1
    • Flip open the LCD panel to get to the side panel.
    • Remove the three 5.5 mm Phillips #00 screws.
    Ask FixBot
  8. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 8, image 1 of 1
    • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
    Ask FixBot
  9. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 9, image 1 of 1
    • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
    Ask FixBot
  10. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 10, image 1 of 2 Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 10, image 2 of 2
    • Orient the camera so the bottom is facing you.
    • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
    • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
    Ask FixBot
  11. Sony Handycam HDR-CX380 Shutter Assembly Replacement, Lens Cover Panel: step 11, image 1 of 1
    • Orient the camera such that the lens is facing to your left.
    • Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
    • The camera should be oriented with the lens pointing to your left.
    Ask FixBot
  12. Sony Handycam HDR-CX380 Shutter Assembly Replacement, Shutter Assembly: step 12, image 1 of 1
    • Rotate the camera so that it is upright and the lens is pointed to your left.
    • Using your right hand to hold the screwdriver and your left to hold the camera, remove the single 5.5 mm Phillips #00 screw from on the top of the shutter assembly.
    Ask FixBot
  13. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 13, image 1 of 1
    • Rotate the camera such that the lens is pointed downward and the LCD screen points to your right.
    • Remove the two Phillips #00 screws from the LCD screen's hinge.
    Ask FixBot
  14. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 14, image 1 of 2 Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 14, image 2 of 2
    • Orient the camera such that it is upright and the lens is facing to your right.
    • Using your left hand to hold the camera, gently remove the shutter assembly from the hull with your right hand.
    • If you are only trying to remove the lens, you do not need to perform the next two steps.
    Ask FixBot
  15. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 15, image 1 of 1
    Tool used on this step:
    Buy
    • Orient the camera such that the bottom is facing toward you and the lens is facing to your right.
    • Using your metal tweezers, gently remove the wire harness connecting the shutter assembly to the motherboard.
    Ask FixBot
  16. Sony Handycam HDR-CX380 Shutter Assembly Replacement: step 16, image 1 of 1
    • Rotate the camera so that it is upright and the lens is facing to your right.
    • Remove the ribbon cable connecting the shutter assembly to the motherboard using your metal tweezers.
    • Be sure to pull the ribbon cable gently, as ribbon cables are easy to damage and can require soldering to repair.
    Ask FixBot
John Santoro
729 Reputation
5 Guides authored
USF Tampa, Team 16-5, Blackwell Winter 2016 Member of USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 556
