Sony Handycam HDR-CX380 Camera Shell Replacement
    1. Sony Handycam HDR-CX380 Camera Shell Replacement, Battery: step 1, image 1 of 1
      • Rotate your camera such that the underside is facing you and the lens is facing the ground.
      • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
      Ask FixBot
    2. Sony Handycam HDR-CX380 Camera Shell Replacement: step 2, image 1 of 1
      • Using your left thumb, push down the slider to the left of the SD card slot.
      • When inserting a new battery or reinserting the one you removed, you can ignore this step.
      Ask FixBot
    3. Sony Handycam HDR-CX380 Camera Shell Replacement: step 3, image 1 of 2 Sony Handycam HDR-CX380 Camera Shell Replacement: step 3, image 2 of 2
      • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
      Ask FixBot
    1. Sony Handycam HDR-CX380 Camera Shell Replacement, Camera Shell: step 4, image 1 of 1
      • Orient the camera with the battery side facing up.
      Ask FixBot
    2. Sony Handycam HDR-CX380 Camera Shell Replacement: step 5, image 1 of 1
      • Remove the single 4.5 mm Phillips #00 screw.
      • Remove the single 5.5 mm Phillips #00 screw.
      Ask FixBot
    3. Sony Handycam HDR-CX380 Camera Shell Replacement: step 6, image 1 of 2 Sony Handycam HDR-CX380 Camera Shell Replacement: step 6, image 2 of 2
      • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
      • Remove the casing using your right thumb and index finger.
      Ask FixBot
    4. Sony Handycam HDR-CX380 Camera Shell Replacement: step 7, image 1 of 1
      • Flip open the LCD panel to get to the side panel.
      • Remove the three 5.5 mm Phillips #00 screws.
      Ask FixBot
    5. Sony Handycam HDR-CX380 Camera Shell Replacement: step 8, image 1 of 1
      • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
      Ask FixBot
    6. Sony Handycam HDR-CX380 Camera Shell Replacement: step 9, image 1 of 1
      • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
      Ask FixBot
    7. Sony Handycam HDR-CX380 Camera Shell Replacement: step 10, image 1 of 2 Sony Handycam HDR-CX380 Camera Shell Replacement: step 10, image 2 of 2
      • Orient the camera so the bottom is facing you.
      • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
      • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
      Ask FixBot
Zackary Williams
457 Reputation
3 Guides authored
USF Tampa, Team 16-5, Blackwell Winter 2016 Member of USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 620
