Introduction
Use this repair guide to remove and replace the Sony Handycam DCR DVD103 lens.
If the Sony Handycam DCR DVD103 has a cracked or broken lens, this repair guide will help the camera perform as designed. This repair does not require special skills.
The camera featured in this repair guide does not contain a battery.
Turn the camera so the back side, beneath the viewfinder, is facing you.
Locate the battery pack compartment.
Press the small release button near the battery compartment.
While pressing the button, slide the switch forward to unlock the battery.
Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
2 other people completed this guide.
