Sony Handycam CX260V Camera Lens Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
85
All Time:
1,420
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will provide accurate steps in replacing the Camera Lens for the CX260V.
Tools
    1. Sony Handycam CX260V Camera Lens Replacement, Housing: step 1, image 1 of 1
      • Remove the 3 mm screw and two 5 mm screws using a Phillips #00 screwdriver from the battery assembly area.
      Ask FixBot
    2. Sony Handycam CX260V Camera Lens Replacement: step 2, image 1 of 1
      • Remove the top and bottom 5 mm screws from the joint connecting the LCD screen to the camera.
      • Remove the middle 3 mm screw.
      Ask FixBot
    3. Sony Handycam CX260V Camera Lens Replacement: step 3, image 1 of 1
      • Remove the two 5 mm screws from above the power button and Dolby logo.
      Ask FixBot
    4. Sony Handycam CX260V Camera Lens Replacement: step 4, image 1 of 1
      • Use a plastic opening tool or other piece of thin angled plastic to remove the button’s cover.
      Ask FixBot
    5. Sony Handycam CX260V Camera Lens Replacement: step 5, image 1 of 1
      • Remove the five 5mm screws located on the bottom panel.
      • Remove the panel to expose the internal motherboard.
      Ask FixBot
    6. Sony Handycam CX260V Camera Lens Replacement: step 6, image 1 of 1
      • Remove the two 5mm screws adjacent to the lens on the opposite side from the LCD screen attachment joint.
      • Remove the nearby leather strap.
      Ask FixBot
    7. Sony Handycam CX260V Camera Lens Replacement: step 7, image 1 of 1
      • Remove the panel from the side where the leather strap was located.
      • Rotate the camera back to the other side and remove the 5mm screw to the left of the record button.
      Ask FixBot
    8. Sony Handycam CX260V Camera Lens Replacement: step 8, image 1 of 1
      • Locate the LCD joint cover on the right side of the lens and remove with a spudger or other wide flat-headed object.
      Ask FixBot
    9. Sony Handycam CX260V Camera Lens Replacement: step 9, image 1 of 2 Sony Handycam CX260V Camera Lens Replacement: step 9, image 2 of 2
      • Orient the camera to the side opposite of the recording buttons where the leather strap was. Locate the orange motherboard and remove the three nearby 5mm black screws and 4mm silver screw.
      • The silver screw is located on the front right-side of the camera and is attached to the main panel.
      Ask FixBot
    10. Sony Handycam CX260V Camera Lens Replacement: step 10, image 1 of 1
      • Locate the 5mm screw that is next to both the LCD attachment joint and the camera lens before removing it.
      Ask FixBot
    11. Sony Handycam CX260V Camera Lens Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, carefully detach the black and white wire connected to the bottom of the motherboard near the lens panel.
      • One white wire, one black wire, and one flat yellow wire are connected to the lens panel.
      • Remove the lens panel.
      Ask FixBot
    12. Sony Handycam CX260V Camera Lens Replacement: step 12, image 1 of 1
      • Locate the three 5mm screws holding the lens in place and remove them.
      • One is at the bottom and two are at the top of the lens area.
      • Carefully remove the lens by hand or with a spudger.
      • Do not lose the three springs located underneath the lens.
      Ask FixBot
    13. Sony Handycam CX260V Camera Lens Replacement: step 13, image 1 of 1
      • Remove a 5mm screw at the back of the camera next to the zoom and picture capturing control buttons.
      • Unplug or carefully set aside the two flat blue wires keeping the buttons connected to the camera.
      • This will partially remove the zoom and picture capturing control.
      Ask FixBot
    14. Sony Handycam CX260V Camera Lens Replacement: step 14, image 1 of 1
      • Remove the silver 5mm screw connected to the tripod mount to expose the mount assembly.
      Ask FixBot
    15. Sony Handycam CX260V Camera Lens Replacement: step 15, image 1 of 1
      • Unplug the wire attached to the orange motherboard.
      • Remove the 5mm silver screw underneath the wire.
      Ask FixBot
    16. Sony Handycam CX260V Camera Lens Replacement: step 16, image 1 of 1
      • Locate the clip that the other end of the wire that attaches the main internal system from the main frame.
      • Release the clip with tweezers and unplug the cords running through the side panel’s frame, which will allow the rest of the camera to be freely taken apart.
      Ask FixBot
    1. Sony Handycam CX260V Camera Lens Replacement, Camera Lens: step 17, image 1 of 2 Sony Handycam CX260V Camera Lens Replacement, Camera Lens: step 17, image 2 of 2
      • Using the PH #00 size screw driver, unscrew one 5 millimeter screw located on the top left near the lens of the camera.
      Ask FixBot
    2. Sony Handycam CX260V Camera Lens Replacement: step 18, image 1 of 1
      Buy
      • Using a pair of tweezers, carefully disassemble the two wires connected to the bottom motherboard portion of the camera.
      • There is one white & black wire and one flat yellow wire that are connected to the lens panel.
      Ask FixBot
    3. Sony Handycam CX260V Camera Lens Replacement: step 19, image 1 of 2 Sony Handycam CX260V Camera Lens Replacement: step 19, image 2 of 2
      • Using the screwdriver, locate the three five millimeter screws.
      • One is located on the bottom of the lens area, and the other two are located on the top left and right of the lens area.
      • Carefully remove the camera lens with your hands or spudger tool.
      • There are three springs located underneath the lens. (Make sure not to lose them).
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 85
All Time: 1,420
