Up to 20% off select tools
Sony HDR-AS30V Outer Casing Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
108
All Time:
1,492
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is a comprehensive guide on how to disassemble and replace the outer casing of the Sony HDR-AS30V.
    1. Sony HDR-AS30V Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
      • Power off the device. Remove the component jack cover.
      • Open component door.
      • Using the Phillips 00 screwdriver, remove the two screws holding the jack cover in place.
      Ask FixBot
    2. Sony HDR-AS30V Outer Casing Replacement: step 2, image 1 of 1
      • Open the battery door.
      • Slide the battery cap along the length of the camera, then flip the cap outward. Use caution; there may be internal damage affecting the functionality of the sliding mechanism.
      Ask FixBot
    3. Sony HDR-AS30V Outer Casing Replacement: step 3, image 1 of 1
      • Prepare to remove outer casing.
      • Using the 2.5 mm precision slotted screwdriver, insert the tip of the screwdriver under the holder to wedge. Use caution when preparing to wedge apart fragile components.
      Ask FixBot
    4. Sony HDR-AS30V Outer Casing Replacement: step 4, image 1 of 1
      • Separate Casing from Device.
      • With the screwdriver wedged, apply slight force while pulling the casing away from the device. Use caution to avoid causing damage to fragile parts.
      Ask FixBot
    5. Sony HDR-AS30V Outer Casing Replacement: step 5, image 1 of 1
      • With the outer casing pulled away from the device, take note of the orientation of the inner component to avoid an electrical short.
      • Once the orientation of the inner component is noted, slide the inner component out of the casing. You may now replace the broken casing with a new one.
      Ask FixBot
Author
with
Patrick Finney
101 Reputation
1 Guide authored
Penn State, Team 2-12, Kaschak Winter 2015 Member of Penn State, Team 2-12, Kaschak Winter 2015
PSU-KASCHAK-W15S2G12
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 108
All Time: 1,492
