Extend the Left cup and fold the Right cup away via the headband.
This will help protect the other ear pad while you work on this one.
The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
