Sony H.ear On 2 Motherboard Replacement
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Sony H.ear On 2 Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
    Ask FixBot
  2. Sony H.ear On 2 Motherboard Replacement: step 2, image 1 of 2 Sony H.ear On 2 Motherboard Replacement: step 2, image 2 of 2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
    Ask FixBot
  3. Sony H.ear On 2 Motherboard Replacement: step 3, image 1 of 3 Sony H.ear On 2 Motherboard Replacement: step 3, image 2 of 3 Sony H.ear On 2 Motherboard Replacement: step 3, image 3 of 3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see How To Solder and Desolder Connections for help on soldering and desoldering connections.
    Ask FixBot
  4. Sony H.ear On 2 Motherboard Replacement: step 4, image 1 of 2 Sony H.ear On 2 Motherboard Replacement: step 4, image 2 of 2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
    Ask FixBot
  5. Sony H.ear On 2 Motherboard Replacement: step 5, image 1 of 1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
    Ask FixBot
Michael Long
131 Reputation
1 Guide authored
Cal Poly, Team S9-G11, Maness Spring 2019 Member of Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Members
16 Guides authored
1 Guide Comment
where can i find a replacement motherboard for these headphones?
MTL - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 2,174
