Sony H.ear On 2 Ear Cup Replacement
  1. Sony H.ear On 2 Ear Cup Replacement, Ear Cup: step 1, image 1 of 2 Sony H.ear On 2 Ear Cup Replacement, Ear Cup: step 1, image 2 of 2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
    Ask FixBot
  2. Sony H.ear On 2 Ear Cup Replacement: step 2, image 1 of 2 Sony H.ear On 2 Ear Cup Replacement: step 2, image 2 of 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
    Ask FixBot
Alec Saffer
576 Reputation
2 Guides authored
Cal Poly, Team S9-G11, Maness Spring 2019 Member of Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 4,056
