Sony Ericsson z300 Vibrator Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
93
All Time:
2,643
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide shows how to remove the vibrator.
Tools
    1. Sony Ericsson z300 Vibrator Replacement, Back Phone Cover: step 1, image 1 of 1
      • To remove the back cover, use your thumb to press down on the center of case and slide it off.
      Ask FixBot
    1. Sony Ericsson z300 Vibrator Replacement, Battery: step 2, image 1 of 1
      • Using a fingernail lift the battery out of the phone.
      Ask FixBot
    1. Sony Ericsson z300 Vibrator Replacement, Front Phone Cover: step 3, image 1 of 1
      • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
      Ask FixBot
    1. Sony Ericsson z300 Vibrator Replacement, Front Dark Grey Case: step 4, image 1 of 1
      • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
      Ask FixBot
    2. Sony Ericsson z300 Vibrator Replacement: step 5, image 1 of 1
      • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
      Ask FixBot
    3. Sony Ericsson z300 Vibrator Replacement: step 6, image 1 of 1
      • Lift up towards the bottom and slide the case off.
      Ask FixBot
    1. Sony Ericsson z300 Vibrator Replacement, Screens: step 7, image 1 of 1
      • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
      Ask FixBot
    2. Sony Ericsson z300 Vibrator Replacement: step 8, image 1 of 1
      • Lift the ribbon cable connector lock using a plastic opening tool.
      Ask FixBot
    3. Sony Ericsson z300 Vibrator Replacement: step 9, image 1 of 2 Sony Ericsson z300 Vibrator Replacement: step 9, image 2 of 2
      • Slide the black ribbon cable tray out with a plastic opening tool.
      • Shown in the second picture is the try already slid out.
      Ask FixBot
    4. Sony Ericsson z300 Vibrator Replacement: step 10, image 1 of 2 Sony Ericsson z300 Vibrator Replacement: step 10, image 2 of 2
      • Slide the ribbon cable out of the connector.
      • Shown in the second picture is the cable already out.
      Ask FixBot
    5. Sony Ericsson z300 Vibrator Replacement: step 11, image 1 of 1
      • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
      • Lift the entire board out of the phone to remove both screens.
      Ask FixBot
    1. Sony Ericsson z300 Vibrator Replacement, Vibrator: step 12, image 1 of 1
      • Use a plastic opening tool to lift the vibrator out of its slot.
      Ask FixBot
Alex Serventi
65 Reputation
13 Guides authored
Cal Poly, Team 5-15, Maness Fall 2010 Member of Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 93
All Time: 2,643
