Sony Ericsson z300 Microphone Replacement
    1. Sony Ericsson z300 Microphone Replacement, Back Phone Cover: step 1, image 1 of 1
      • To remove the back cover, use your thumb to press down on the center of case and slide it off.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Battery: step 2, image 1 of 1
      • Using a fingernail lift the battery out of the phone.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Sim Card: step 3, image 1 of 1
      • Slide the sim card out with your thumb.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Back Dark Grey Case: step 4, image 1 of 1
      • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
      Ask FixBot
    2. Sony Ericsson z300 Microphone Replacement: step 5, image 1 of 1
      • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
      Ask FixBot
    3. Sony Ericsson z300 Microphone Replacement: step 6, image 1 of 1
      • Lift up towards the bottom and slide the case off.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Motherboard: step 7, image 1 of 1
      • Use a plastic opening tool to lift up the brass colored panel.
      Ask FixBot
    2. Sony Ericsson z300 Microphone Replacement: step 8, image 1 of 1
      • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
      Ask FixBot
    3. Sony Ericsson z300 Microphone Replacement: step 9, image 1 of 1
      • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Keypad: step 10, image 1 of 1
      • Using a plastic opening tool lift up the keypad to remove it.
      Ask FixBot
    1. Sony Ericsson z300 Microphone Replacement, Microphone: step 11, image 1 of 1
      • Use a plastic opening tool to lift the microphone out of its circular slot.
      Ask FixBot
Alex Serventi
65 Reputation
13 Guides authored
Cal Poly, Team 5-15, Maness Fall 2010 Member of Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,204
