Sony Ericsson z300 Keypad Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
81
All Time:
1,786
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide shows how to remove the Keypad.
Tools
    1. Sony Ericsson z300 Keypad Replacement, Back Phone Cover: step 1, image 1 of 1
      • To remove the back cover, use your thumb to press down on the center of case and slide it off.
      Ask FixBot
    1. Sony Ericsson z300 Keypad Replacement, Battery: step 2, image 1 of 1
      • Using a fingernail lift the battery out of the phone.
      Ask FixBot
    1. Sony Ericsson z300 Keypad Replacement, Sim Card: step 3, image 1 of 1
      • Slide the sim card out with your thumb.
      Ask FixBot
    1. Sony Ericsson z300 Keypad Replacement, Back Dark Grey Case: step 4, image 1 of 1
      • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
      Ask FixBot
    2. Sony Ericsson z300 Keypad Replacement: step 5, image 1 of 1
      • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
      Ask FixBot
    3. Sony Ericsson z300 Keypad Replacement: step 6, image 1 of 1
      • Lift up towards the bottom and slide the case off.
      Ask FixBot
    1. Sony Ericsson z300 Keypad Replacement, Motherboard: step 7, image 1 of 1
      • Use a plastic opening tool to lift up the brass colored panel.
      Ask FixBot
    2. Sony Ericsson z300 Keypad Replacement: step 8, image 1 of 1
      • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
      Ask FixBot
    3. Sony Ericsson z300 Keypad Replacement: step 9, image 1 of 1
      • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
      Ask FixBot
    1. Sony Ericsson z300 Keypad Replacement, Keypad: step 10, image 1 of 1
      • Using a plastic opening tool lift up the keypad to remove it.
      Ask FixBot
Alex Serventi
65 Reputation
13 Guides authored
Cal Poly, Team 5-15, Maness Fall 2010 Member of Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Members
156 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 81
All Time: 1,786
