Sony Ericsson xPeria Active Camera Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
103
All Time:
1,280
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The camera on a phone can break from water damage, physical force, faulty wiring to the camera, or the camera could have faulty manufacturing. Whatever the reason may be, this guide will walk you through how to replace your camera and back to taking selfies in no time.
Tools
    1. Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 1 of 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 2 of 3 Sony Ericsson xPeria Active Camera Replacement, Remove the back cover.: step 1, image 3 of 3
      • Open the flaps and remove the back cover using the plastic opening device.
      Ask FixBot
    2. Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: step 2, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove inside plastic battery cover.: step 2, image 2 of 2
      • Remove the battery shield with the plastic opening device.
      Ask FixBot
    3. Sony Ericsson xPeria Active Camera Replacement, Remove the battery: step 3, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove the battery: step 3, image 2 of 2
      • Remove the battery.
      Ask FixBot
    1. Sony Ericsson xPeria Active Camera Replacement, Unfastening The Motherboard Cover: step 4, image 1 of 1
      • Unscrew the 5mm screws with the T5 head.
      • Unscrew the 6mm screw with the T6 head.
      Ask FixBot
    2. Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: step 5, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Removing The Motherboard Cover: step 5, image 2 of 2
      • Remove the black cover with the plastic opening tool.
      • Remove the headphone jack from its slot.
      Ask FixBot
    1. Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: step 6, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Unplug the back motherboard plug.: step 6, image 2 of 2
      • Unplug the plug from the motherboard.
      Ask FixBot
    2. Sony Ericsson xPeria Active Camera Replacement, Remove motherboard from device case.: step 7, image 1 of 1
      • Using the plastic opening tool, carefully pry up on the edges of the motherboard, opposite of the jacks.
      Ask FixBot
    3. Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: step 8, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove the display ribbon cable: step 8, image 2 of 2
      • Carefully pry up on the tab holding down the display ribbon cable and remove the ribbon cable.
      Ask FixBot
    4. Sony Ericsson xPeria Active Camera Replacement: step 9, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement: step 9, image 2 of 2
      • Use the plastic opening tool to pry the ribbon cable away from the motherboard.
      Ask FixBot
    5. Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: step 10, image 1 of 2 Sony Ericsson xPeria Active Camera Replacement, Remove camera from device: step 10, image 2 of 2
      • Pull the camera out through the front of the motherboard.
      Ask FixBot
Alex Tobin
430 Reputation
3 Guides authored
USF Tampa, Team 14-5, Leahy Fall 2014 Member of USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 103
All Time: 1,280
