Sony Ericsson s710a SIM Card Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
87
All Time:
2,410
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Mismatched Prerequisites
This guide does not have a proper prerequisite guide. Help match it to its ideal partner by finding it or writing one!
Introduction
Go to step 1 ↓
This is a GSM phone originally introduced by AT&T. The SIM card will likely be an AT&T card; however, when in foreign countries, other SIM cards can be inserted into the phone for compatibility with foreign carriers.
    1. Sony Ericsson s710a SIM Card Replacement, SIM Card: step 1, image 1 of 1
      • Slide the battery cover off by pushing it away from the camera side of the device.
      • This may require a good amount of force.
      Ask FixBot
    2. Sony Ericsson s710a SIM Card Replacement: step 2, image 1 of 1
      • Next remove the battery
      • Lift it out of the phone using the tab on the battery (marked in the image)
      Ask FixBot
    3. Sony Ericsson s710a SIM Card Replacement: step 3, image 1 of 1
      • The SIM card holder is now exposed (marked in image).
      • This will likely already have an existing SIM card in it if the phone has been previously used.
      • To open this, slide the holder upward (assuming the same orientation as in the image)
      Ask FixBot
    4. Sony Ericsson s710a SIM Card Replacement: step 4, image 1 of 1
      • The holder will then hinge open.
      • You are now able to insert a new SIM card.
      Ask FixBot
    5. Sony Ericsson s710a SIM Card Replacement: step 5, image 1 of 1
      • Insert the new SIM card in the orientation shown.
      • This is important, as the phone will not work if the metal contacts on the card are not properly aligned with the contacts on the phone.
      Ask FixBot
    6. Sony Ericsson s710a SIM Card Replacement: step 6, image 1 of 1
      • Now hinge the SIM card holder down so that it lays flat in the phone.
      • Slide the plastic holder downwards to lock it in place.
      • Now the battery and cover can be put back in place.
      Ask FixBot
Alexander
75 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 87
All Time: 2,410
