Sony Ericsson s710a Motherboard Replacement
  1. Sony Ericsson s710a Motherboard Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover by sliding it off.
    Ask FixBot
  2. Sony Ericsson s710a Motherboard Replacement: step 2, image 1 of 1
    • Pull the battery out using your finger.
    Ask FixBot
  3. Sony Ericsson s710a Motherboard Replacement: step 3, image 1 of 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
    Ask FixBot
  4. Sony Ericsson s710a Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Locate the four 6mm screws on the back of the phone.
    • Using a small Phillips head screwdriver, remove the four screws.
    Ask FixBot
  5. Sony Ericsson s710a Motherboard Replacement: step 5, image 1 of 2 Sony Ericsson s710a Motherboard Replacement: step 5, image 2 of 2
    • Flip the phone over and slide it open.
    • Using the prying tool, remove the plastic piece covering the microphone.
    • Locate and remove the two 6mm screws located under the plastic piece and remove them using a small Phillips screwdriver.
    Ask FixBot
  6. Sony Ericsson s710a Motherboard Replacement: step 6, image 1 of 3 Sony Ericsson s710a Motherboard Replacement: step 6, image 2 of 3 Sony Ericsson s710a Motherboard Replacement: step 6, image 3 of 3
    • Use the plastic opening tool to remove the black plastic cover from the rest of the phone.
    • It is best to start from the bottom of the phone by the memory card slot.
    • Potential for device damage: Excessive force is unnecessary here! The plastic cover should pop off quite easily with the tool.
    Ask FixBot
  7. Sony Ericsson s710a Motherboard Replacement: step 7, image 1 of 1
    • Once the back cover is removed, remove the small black piece shown in the picture.
    Ask FixBot
  8. Sony Ericsson s710a Motherboard Replacement: step 8, image 1 of 1
    • Using the plastic opening tool, slide around the motherboard to loosen it.
    • Lift the motherboard up, but not completely, as in order to remove it you need to lift and pull.
    Ask FixBot
  9. Sony Ericsson s710a Motherboard Replacement: step 9, image 1 of 2 Sony Ericsson s710a Motherboard Replacement: step 9, image 2 of 2
    • Using the plastic opening tool, separate the connectors to the screen.
    • Potential for device damage: Make sure to note the orientation and location of each cable before disconnecting. This will ensure that the motherboard will be reconnected properly.
    • Once the old motherboard is removed insert the new one if desired, and then reassemble the phone.
    Ask FixBot
Mike
31 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 37
All Time: 1,765
