Introduction
This guide will show the steps for replacing the Sony Ericsson s710a battery and LCD screen. You can use this guide if the battery or LCD screen has been damaged and needs to be replaced or repaired. This guide can also be used to check the connection between the screen and the motherboard.
Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
