Up to 20% off select tools
Sony Ericsson Z500a Keypad Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
20
All Time:
3,200
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide shows how to remove the phone keypad.
    1. Sony Ericsson Z500a Keypad Replacement, Keypad: step 1, image 1 of 3 Sony Ericsson Z500a Keypad Replacement, Keypad: step 1, image 2 of 3 Sony Ericsson Z500a Keypad Replacement, Keypad: step 1, image 3 of 3
      • Remove the back cover by pulling it down, and then take out the battery.
      • Using a T6 Torx screwdriver, remove the 4 screws.
      • Keep the phone open with the back cover facing you.
      Ask FixBot
    2. Sony Ericsson Z500a Keypad Replacement: step 2, image 1 of 1
      • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
      • There are 2 clamps that lock the keyboard to the case (1 on each side)
      Ask FixBot
    3. Sony Ericsson Z500a Keypad Replacement: step 3, image 1 of 1
      • Flip the phone over and lift straight up on the key pad to remove it.
      • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
      Ask FixBot
Author
with
Jory Benitez
1 Reputation
1 Guide authored
Cal Poly, Team 7-12, Maness Spring 2010 Member of Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 3,200
