Sony Ericsson Xperia Pro MK16A Power Button Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
106
All Time:
1,167
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Follow this guide to install a new power button in about 5 minutes.
Tools
    1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: step 1, image 1 of 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: step 1, image 2 of 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Taking the Back Off: step 1, image 3 of 3
      • Use a plastic opening tool to get the back cover off your phone.
      • The plastic opener will work on any side, but be careful and pry gently.
      Ask FixBot
    2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Removing the Battery: step 2, image 1 of 1
      • Locate the battery in your phone.
      • Find the divot below the battery.
      • Use your thumb to lift the battery out of the phone.
      Ask FixBot
    1. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: step 3, image 1 of 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: step 3, image 2 of 3 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Screws: step 3, image 3 of 3
      • Remove the 4 black screws with the Phillips screwdriver.
      • Remove the 4 silver screws with the Torx screwdriver.
      Ask FixBot
    2. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Remove Back Case: step 4, image 1 of 1
      • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
      Ask FixBot
    3. Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: step 5, image 1 of 2 Sony Ericsson Xperia Pro MK16A Power Button Replacement, Replacing the Power Button: step 5, image 2 of 2
      • When the inner back cover is off, locate and remove the power button.
      Ask FixBot
John Emery
65 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 106
All Time: 1,167
