Sony Ericsson W580i LCD Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
106
All Time:
6,498
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to help you replace the LCD.
Parts
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
    1. Sony Ericsson W580i LCD Replacement, Front Cover: step 1, image 1 of 2 Sony Ericsson W580i LCD Replacement, Front Cover: step 1, image 2 of 2
      • Insert the edge of an opening tool between the front cover and the phone.
      • Gently pry off the front cover working your way around the edges.
      Ask FixBot
    2. Sony Ericsson W580i LCD Replacement: step 2, image 1 of 2 Sony Ericsson W580i LCD Replacement: step 2, image 2 of 2
      • Pull the front cover down and away from the phone.
      • The front keypads might come off with the front cover. Do not lose these.
      Ask FixBot
    3. Sony Ericsson W580i LCD Replacement: step 3, image 1 of 1
      • Gently peel the keypad away from the phone.
      Ask FixBot
    1. Sony Ericsson W580i LCD Replacement, LCD: step 4, image 1 of 2 Sony Ericsson W580i LCD Replacement, LCD: step 4, image 2 of 2
      • Insert a spudger between the lower edge of the screen and the phone.
      • Pry the screen up to disconnect the tabs on each side holding the screen in.
      • Do not remove the screen yet. There is a ribbon connecting the screen to the motherboard.
      Ask FixBot
    2. Sony Ericsson W580i LCD Replacement: step 5, image 1 of 2 Sony Ericsson W580i LCD Replacement: step 5, image 2 of 2
      • Use a spudger to remove the ribbon cable from the motherboard.
      • Lift the screen away from the phone
      Ask FixBot
6 other people completed this guide.
Diego
397 Reputation
4 Guides authored
Cal Poly, Team 5-31, Amido Fall 2011 Member of Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 106
All Time: 6,498
