Sony Ericsson W518a Camera Lens Replacement
    1. Sony Ericsson W518a Camera Lens Replacement, Faceplate: step 1, image 1 of 1
      • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
      Ask FixBot
    2. Sony Ericsson W518a Camera Lens Replacement: step 2, image 1 of 3 Sony Ericsson W518a Camera Lens Replacement: step 2, image 2 of 3 Sony Ericsson W518a Camera Lens Replacement: step 2, image 3 of 3
      • Insert your plastic opening tool into the notch.
      • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
      • When enough of the faceplate has been lifted it can be easily removed.
      • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
      Ask FixBot
    1. Sony Ericsson W518a Camera Lens Replacement, Camera Lens: step 3, image 1 of 1
      • Remove the four 2mm Phillips screws from the back housing of the phone.
      Ask FixBot
    2. Sony Ericsson W518a Camera Lens Replacement: step 4, image 1 of 3 Sony Ericsson W518a Camera Lens Replacement: step 4, image 2 of 3 Sony Ericsson W518a Camera Lens Replacement: step 4, image 3 of 3
      • Insert the plastic opening tool in the notch at the top corner of the phone.
      • Lift the corner and run the plastic opening tool around the phone until the back housing can easily be removed.
      Ask FixBot
    3. Sony Ericsson W518a Camera Lens Replacement: step 5, image 1 of 2 Sony Ericsson W518a Camera Lens Replacement: step 5, image 2 of 2
      • Remove the lends by pushing the lens from the inside of the housing.
      Ask FixBot
kgkramer
121 Reputation
2 Guides authored
Cal Poly, Team 1-5, Regan SU 2012 Member of Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 1,473
