Sony Ericsson TM506 Sound Box Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,274
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide provides instruction for installing a sound box for the Sony Ericsson TM506 cell phone.
Tools
    1. Sony Ericsson TM506 Sound Box Replacement, Battery Cover: step 1, image 1 of 3 Sony Ericsson TM506 Sound Box Replacement, Battery Cover: step 1, image 2 of 3 Sony Ericsson TM506 Sound Box Replacement, Battery Cover: step 1, image 3 of 3
      • Firmly hold the phone between your fingers with your thumb on the battery cover.
      • Push down with your thumb until the battery cover comes off.
      Ask FixBot
    1. Sony Ericsson TM506 Sound Box Replacement, Back Case: step 2, image 1 of 3 Sony Ericsson TM506 Sound Box Replacement, Back Case: step 2, image 2 of 3 Sony Ericsson TM506 Sound Box Replacement, Back Case: step 2, image 3 of 3
      • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    2. Sony Ericsson TM506 Sound Box Replacement: step 3, image 1 of 2 Sony Ericsson TM506 Sound Box Replacement: step 3, image 2 of 2
      • Remove the two rubber casings for the top two screws with a plastic opening tool.
      Ask FixBot
    3. Sony Ericsson TM506 Sound Box Replacement: step 4, image 1 of 1
      • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    4. Sony Ericsson TM506 Sound Box Replacement: step 5, image 1 of 3 Sony Ericsson TM506 Sound Box Replacement: step 5, image 2 of 3 Sony Ericsson TM506 Sound Box Replacement: step 5, image 3 of 3
      • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
      Ask FixBot
    1. Sony Ericsson TM506 Sound Box Replacement, Sound Box: step 6, image 1 of 3 Sony Ericsson TM506 Sound Box Replacement, Sound Box: step 6, image 2 of 3 Sony Ericsson TM506 Sound Box Replacement, Sound Box: step 6, image 3 of 3
      • The sound box is attached to the case by two snap hooks.
      • Lift the sound box up to remove it from the case.
      Ask FixBot
Daniel
98 Reputation
7 Guides authored
Cal Poly, Team 1-1, Regan SU 2012 Member of Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,274
