Sony Ericsson TM506 Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
1,635
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide provides instruction for installing a screen for the Sony Ericsson TM506 cell phone.
Tools
    1. Sony Ericsson TM506 Screen Replacement, Battery Cover: step 1, image 1 of 3 Sony Ericsson TM506 Screen Replacement, Battery Cover: step 1, image 2 of 3 Sony Ericsson TM506 Screen Replacement, Battery Cover: step 1, image 3 of 3
      • Firmly hold the phone between your fingers with your thumb on the battery cover.
      • Push down with your thumb until the battery cover comes off.
      Ask FixBot
    1. Sony Ericsson TM506 Screen Replacement, Back Case: step 2, image 1 of 3 Sony Ericsson TM506 Screen Replacement, Back Case: step 2, image 2 of 3 Sony Ericsson TM506 Screen Replacement, Back Case: step 2, image 3 of 3
      • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    2. Sony Ericsson TM506 Screen Replacement: step 3, image 1 of 2 Sony Ericsson TM506 Screen Replacement: step 3, image 2 of 2
      • Remove the two rubber casings for the top two screws with a plastic opening tool.
      Ask FixBot
    3. Sony Ericsson TM506 Screen Replacement: step 4, image 1 of 1
      • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    4. Sony Ericsson TM506 Screen Replacement: step 5, image 1 of 3 Sony Ericsson TM506 Screen Replacement: step 5, image 2 of 3 Sony Ericsson TM506 Screen Replacement: step 5, image 3 of 3
      • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
      Ask FixBot
    1. Sony Ericsson TM506 Screen Replacement, Sound Box: step 6, image 1 of 3 Sony Ericsson TM506 Screen Replacement, Sound Box: step 6, image 2 of 3 Sony Ericsson TM506 Screen Replacement, Sound Box: step 6, image 3 of 3
      • The sound box is attached to the case by two snap hooks.
      • Lift the sound box up to remove it from the case.
      Ask FixBot
    1. Sony Ericsson TM506 Screen Replacement, Motherboard: step 7, image 1 of 2 Sony Ericsson TM506 Screen Replacement, Motherboard: step 7, image 2 of 2
      • Locate the 80-pin connector.
      • Carefully, lift up on the connector to separate it from the board.
      Ask FixBot
    2. Sony Ericsson TM506 Screen Replacement: step 8, image 1 of 3 Sony Ericsson TM506 Screen Replacement: step 8, image 2 of 3 Sony Ericsson TM506 Screen Replacement: step 8, image 3 of 3
      • There are two snap hooks that attach the motherboard to the case.
      • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
      • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
      Ask FixBot
    1. Sony Ericsson TM506 Screen Replacement, Speaker, GPS, and Camera: step 9, image 1 of 2 Sony Ericsson TM506 Screen Replacement, Speaker, GPS, and Camera: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to push the hinge stopper in until it can no longer be moved.
      • The hinge stopper should be about 5.5mm in.
      Ask FixBot
    2. Sony Ericsson TM506 Screen Replacement: step 10, image 1 of 2 Sony Ericsson TM506 Screen Replacement: step 10, image 2 of 2
      • Separate the bottom and top half of the phone from the hinge they are connected by.
      • Don't completely pull apart the two pieces or you will damage the ribbon.
      Ask FixBot
    3. Sony Ericsson TM506 Screen Replacement: step 11, image 1 of 1
      • Pull the ribbon through the opening in the hinge to completely separate the upper and lower halves of the phone.
      Ask FixBot
    4. Sony Ericsson TM506 Screen Replacement: step 12, image 1 of 3 Sony Ericsson TM506 Screen Replacement: step 12, image 2 of 3 Sony Ericsson TM506 Screen Replacement: step 12, image 3 of 3
      • The top and bottom covers are held in place by adhesive. To remove them, use a pushpin in the four indentations indicated to remove.
      Ask FixBot
    5. Sony Ericsson TM506 Screen Replacement: step 13, image 1 of 2 Sony Ericsson TM506 Screen Replacement: step 13, image 2 of 2
      • Remove the four 5.4 mm screws with a Torx T5 screwdriver.
      Ask FixBot
    6. Sony Ericsson TM506 Screen Replacement: step 14, image 1 of 3 Sony Ericsson TM506 Screen Replacement: step 14, image 2 of 3 Sony Ericsson TM506 Screen Replacement: step 14, image 3 of 3
      • Use a plastic opening tool in the indicated location and apply pressure until the case hook is detached. Then lift the case up until the two pieces are detached.
      Ask FixBot
    7. Sony Ericsson TM506 Screen Replacement: step 15, image 1 of 3 Sony Ericsson TM506 Screen Replacement: step 15, image 2 of 3 Sony Ericsson TM506 Screen Replacement: step 15, image 3 of 3
      • Use a paperclip to detach the speaker from the case.
      • Detach the GPS from the case by carefully lifting it up from the case.
      • Detach the camera with your hands or by using a paperclip similar to the way the speaker was removed.
      Ask FixBot
    8. Sony Ericsson TM506 Screen Replacement: step 16, image 1 of 2 Sony Ericsson TM506 Screen Replacement: step 16, image 2 of 2
      • Once the three components are detached, removing the ribbon is possible.
      • Simply, move the ribbon to the right and it will be completely detached from the case.
      Ask FixBot
    1. Sony Ericsson TM506 Screen Replacement, Screen: step 17, image 1 of 3 Sony Ericsson TM506 Screen Replacement, Screen: step 17, image 2 of 3 Sony Ericsson TM506 Screen Replacement, Screen: step 17, image 3 of 3
      • Pull apart the screen and the case at one end. Then slide the screen out to completely detach them.
      Ask FixBot
Daniel
98 Reputation
7 Guides authored
Cal Poly, Team 1-1, Regan SU 2012 Member of Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,635
