Sony Ericsson TM506 Motherboard Replacement
    1. Sony Ericsson TM506 Motherboard Replacement, Battery Cover: step 1, image 1 of 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: step 1, image 2 of 3 Sony Ericsson TM506 Motherboard Replacement, Battery Cover: step 1, image 3 of 3
      • Firmly hold the phone between your fingers with your thumb on the battery cover.
      • Push down with your thumb until the battery cover comes off.
      Ask FixBot
    1. Sony Ericsson TM506 Motherboard Replacement, Back Case: step 2, image 1 of 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: step 2, image 2 of 3 Sony Ericsson TM506 Motherboard Replacement, Back Case: step 2, image 3 of 3
      • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    2. Sony Ericsson TM506 Motherboard Replacement: step 3, image 1 of 2 Sony Ericsson TM506 Motherboard Replacement: step 3, image 2 of 2
      • Remove the two rubber casings for the top two screws with a plastic opening tool.
      Ask FixBot
    3. Sony Ericsson TM506 Motherboard Replacement: step 4, image 1 of 1
      • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    4. Sony Ericsson TM506 Motherboard Replacement: step 5, image 1 of 3 Sony Ericsson TM506 Motherboard Replacement: step 5, image 2 of 3 Sony Ericsson TM506 Motherboard Replacement: step 5, image 3 of 3
      • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
      Ask FixBot
    1. Sony Ericsson TM506 Motherboard Replacement, Sound Box: step 6, image 1 of 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: step 6, image 2 of 3 Sony Ericsson TM506 Motherboard Replacement, Sound Box: step 6, image 3 of 3
      • The sound box is attached to the case by two snap hooks.
      • Lift the sound box up to remove it from the case.
      Ask FixBot
    1. Sony Ericsson TM506 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Sony Ericsson TM506 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Locate the 80-pin connector.
      • Carefully, lift up on the connector to separate it from the board.
      Ask FixBot
    2. Sony Ericsson TM506 Motherboard Replacement: step 8, image 1 of 3 Sony Ericsson TM506 Motherboard Replacement: step 8, image 2 of 3 Sony Ericsson TM506 Motherboard Replacement: step 8, image 3 of 3
      • There are two snap hooks that attach the motherboard to the case.
      • Using a plastic opening tool, carefully lift up on the motherboard to detach it.
      • The motherboard is extremely fragile. Try to be forceful yet delicate in the removal because it will not come off easily.
      Ask FixBot
Daniel
98 Reputation
7 Guides authored
Cal Poly, Team 1-1, Regan SU 2012 Member of Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 1,518
