Up to 20% off select tools
Sony Ericsson TM506 Back Case Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
8
Past 30 Days:
34
All Time:
920
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide provides instruction for installing a back case for the Sony Ericsson TM506 cell phone.
    1. Sony Ericsson TM506 Back Case Replacement, Battery Cover: step 1, image 1 of 3 Sony Ericsson TM506 Back Case Replacement, Battery Cover: step 1, image 2 of 3 Sony Ericsson TM506 Back Case Replacement, Battery Cover: step 1, image 3 of 3
      • Firmly hold the phone between your fingers with your thumb on the battery cover.
      • Push down with your thumb until the battery cover comes off.
      Ask FixBot
    1. Sony Ericsson TM506 Back Case Replacement, Back Case: step 2, image 1 of 3 Sony Ericsson TM506 Back Case Replacement, Back Case: step 2, image 2 of 3 Sony Ericsson TM506 Back Case Replacement, Back Case: step 2, image 3 of 3
      • Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    2. Sony Ericsson TM506 Back Case Replacement: step 3, image 1 of 2 Sony Ericsson TM506 Back Case Replacement: step 3, image 2 of 2
      • Remove the two rubber casings for the top two screws with a plastic opening tool.
      Ask FixBot
    3. Sony Ericsson TM506 Back Case Replacement: step 4, image 1 of 1
      • Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
      Ask FixBot
    4. Sony Ericsson TM506 Back Case Replacement: step 5, image 1 of 3 Sony Ericsson TM506 Back Case Replacement: step 5, image 2 of 3 Sony Ericsson TM506 Back Case Replacement: step 5, image 3 of 3
      • There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
      Ask FixBot
Author
with
Minnal
31 Reputation
1 Guide authored
Cal Poly, Team 1-1, Regan SU 2012 Member of Cal Poly, Team 1-1, Regan SU 2012
CPSU-REGAN-SU12S1G1
2 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 920
