Sony Ericsson T68i Vibration Motor Replacement
    1. Sony Ericsson T68i Vibration Motor Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson T68i Vibration Motor Replacement, Keypad: step 1, image 2 of 2
      • Remove the battery from the back.
      Ask FixBot
    2. Sony Ericsson T68i Vibration Motor Replacement: step 2, image 1 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 2, image 2 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 2, image 3 of 3
      • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
      • Do not bend it too far down, or else you risk breaking the two bottom clips.
      Ask FixBot
    3. Sony Ericsson T68i Vibration Motor Replacement: step 3, image 1 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 3, image 2 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 3, image 3 of 3
      • Unscrew all four Torx T6 screws.
      • Keep in a safe place.
      Ask FixBot
    4. Sony Ericsson T68i Vibration Motor Replacement: step 4, image 1 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 4, image 2 of 3 Sony Ericsson T68i Vibration Motor Replacement: step 4, image 3 of 3
      • After removing the screws, the two halves will separate. If not, then pry them gently apart.
      Ask FixBot
    1. Sony Ericsson T68i Vibration Motor Replacement, Vibration Motor: step 5, image 1 of 2 Sony Ericsson T68i Vibration Motor Replacement, Vibration Motor: step 5, image 2 of 2
      • Remove the vibration motor visible in the front housing.
      Ask FixBot
2 other people completed this guide.
Tim Dascomb
174 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
63 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 2,943
