Up to 20% off select tools
Sony Ericsson T68i Keypad Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
89
All Time:
2,805
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
This guide will help you to remove the keypad from your Sony Ericsson T68i.
    1. Sony Ericsson T68i Keypad Replacement, Keypad: step 1, image 1 of 2 Sony Ericsson T68i Keypad Replacement, Keypad: step 1, image 2 of 2
      • Remove the battery from the back.
      Ask FixBot
    2. Sony Ericsson T68i Keypad Replacement: step 2, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 2, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 2, image 3 of 3
      • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
      • Do not bend it too far down, or else you risk breaking the two bottom clips.
      Ask FixBot
    3. Sony Ericsson T68i Keypad Replacement: step 3, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 3, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 3, image 3 of 3
      • Unscrew all four Torx T6 screws.
      • Keep in a safe place.
      Ask FixBot
    4. Sony Ericsson T68i Keypad Replacement: step 4, image 1 of 3 Sony Ericsson T68i Keypad Replacement: step 4, image 2 of 3 Sony Ericsson T68i Keypad Replacement: step 4, image 3 of 3
      • After removing the screws, the two halves will separate. If not, then pry them gently apart.
      Ask FixBot
Author
with
Tim Dascomb
174 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 89
All Time: 2,805
