Up to 20% off select tools
Sony ECM-MS907 Microphone Disassembly
Views: 6.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
126
All Time:
6,644
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide will show you how to dissemble a Sony ECM-MS907 microphone. This guide will help you if you believe any of the pieces apart of your microphone are broken or dirty that need to be replaced or cleaned.
For names of the microphone parts, please click the link below:
Microphone Parts' Manual
For signs that your microphone is broken, please click the link below:
How to tell if a Microphone is Broken
    1. Sony ECM-MS907 Microphone Disassembly, Microphone: step 1, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the screw securing diaphragm to the base of the microphone.
      Ask FixBot
    2. Sony ECM-MS907 Microphone Disassembly: step 2, image 1 of 2 Sony ECM-MS907 Microphone Disassembly: step 2, image 2 of 2
      • Separate the microphone into two pieces to reveal the internal shield cover.
      Ask FixBot
    3. Sony ECM-MS907 Microphone Disassembly: step 3, image 1 of 1
      • Unscrew the base of the microphone in a clockwise motion and separate the bottom and top of the microphone.
      Ask FixBot
    4. Sony ECM-MS907 Microphone Disassembly: step 4, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the screw directly above the battery.
      Ask FixBot
    5. Sony ECM-MS907 Microphone Disassembly: step 5, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the black screw near the bottom of the microphone.
      Ask FixBot
    6. Sony ECM-MS907 Microphone Disassembly: step 6, image 1 of 3 Sony ECM-MS907 Microphone Disassembly: step 6, image 2 of 3 Sony ECM-MS907 Microphone Disassembly: step 6, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
Attached Documents
Author
with
Kefaya
367 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 126
All Time: 6,644
