Up to 20% off select tools
Sony DualSense Controller Middle Trim Replacement
Views: 21K
View statistics:
Past 24 Hours:
32
Past 7 Days:
249
Past 30 Days:
998
All Time:
21,113
Comments: 3
3 comments on steps.
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the middle trim on a Sony PlayStation 5 DualSense controller.
    1. Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Middle Trim Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
12 other people completed this guide.
Author
with
Sam Omiotek
101,895 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 32
Past 7 Days: 249
Past 30 Days: 998
All Time: 21,113
