Sony DualSense Controller Joystick Cover Replacement
    1. Sony DualSense Controller Joystick Cover Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. Sony DualSense Controller Joystick Cover Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. Sony DualSense Controller Joystick Cover Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. Sony DualSense Controller Joystick Cover Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. Sony DualSense Controller Joystick Cover Replacement: step 9, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. Sony DualSense Controller Joystick Cover Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. Sony DualSense Controller Joystick Cover Replacement: step 11, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement: step 11, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. Sony DualSense Controller Joystick Cover Replacement: step 12, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement: step 12, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. Sony DualSense Controller Joystick Cover Replacement: step 13, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Disconnect the battery: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      Ask FixBot
    2. Sony DualSense Controller Joystick Cover Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Remove the battery: step 16, image 2 of 2
      • Lift the battery straight out of the battery bracket.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Remove the lower microphone: step 17, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Remove the lower microphone: step 17, image 2 of 2
      Buy
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Ask FixBot
    2. Sony DualSense Controller Joystick Cover Replacement, Remove the battery bracket: step 18, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Remove the battery bracket: step 18, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
      Ask FixBot
    3. Sony DualSense Controller Joystick Cover Replacement: step 19, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement: step 19, image 2 of 2
      • Lift the battery bracket out of the motherboard.
      Ask FixBot
    4. Sony DualSense Controller Joystick Cover Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      • Do not completely remove the ribbon cable yet.
      Ask FixBot
    5. Sony DualSense Controller Joystick Cover Replacement: step 21, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement: step 21, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      • Remove the ribbon cable.
      Ask FixBot
    6. Sony DualSense Controller Joystick Cover Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      Ask FixBot
    7. Sony DualSense Controller Joystick Cover Replacement: step 23, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement: step 23, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      Ask FixBot
    8. Sony DualSense Controller Joystick Cover Replacement, Disconnect the upper microphone: step 24, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Disconnect the upper microphone: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
      Ask FixBot
    9. Sony DualSense Controller Joystick Cover Replacement, Disconnect the touchpad: step 25, image 1 of 2 Sony DualSense Controller Joystick Cover Replacement, Disconnect the touchpad: step 25, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
      Ask FixBot
    10. Sony DualSense Controller Joystick Cover Replacement, Lift out the motherboard: step 26, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Lift out the motherboard: step 26, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Lift out the motherboard: step 26, image 3 of 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
      • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
      Ask FixBot
    1. Sony DualSense Controller Joystick Cover Replacement, Remove the joystick covers: step 27, image 1 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the joystick covers: step 27, image 2 of 3 Sony DualSense Controller Joystick Cover Replacement, Remove the joystick covers: step 27, image 3 of 3
      • Use your fingers to pull the joystick covers straight up and off of their modules.
      Ask FixBot
112 other people completed this guide.
Sam Omiotek
100,081 Reputation
289 Guides authored
13 Guide Comments
Sony did ever came up with a modular design on their PSP-1000 (Joystick Replacement) which does not require soldering only contact pins such like Xbox Series X headphone output
Nicholin V - Reply Share
This was really good i manage to fix my controller on my own for the first time. Thanks!
rinie ramli - Reply Share
A great guide, just a few small comments:
1. When removing the R1/L1 buttons - do it gently, otherwise they could fly off around the room. Lucky for me my R1 hit the bookshelf behind me and then landed right next to my hand, but usually that's not the case.
2. DO NOT turn the device upside down while the motherboard is disconnected. There's a small rectangular piece that's not connected to anything and might move around and prevent reassembly or worse - you could lose it and not even know about it. I have no idea what that piece is but I'm sure I want it in my controller.
3. When putting back the motherboard be sure to place the microphone first and make sure the flat cable is accessible to you once the mother board is in place.
asaf.weiss - Reply Share
I just replaced the two sticks of my controller: great tuto, thanks!
Grishka - Reply Share
I replaced my right analog stick to fix stick drift but it got worse, my characters on the game wont stop spinning. I can’t even aim anywhere else it’s like the right stick is stuck moving left, can anyone help?
PuR3_BlixoYT - Reply Share
Past 24 Hours: 155
Past 7 Days: 1,044
Past 30 Days: 4,100
All Time: 175,621
