Up to 20% off select tools
Sony DualSense Controller Front Case Replacement
Views: 59K
View statistics:
Past 24 Hours:
138
Past 7 Days:
740
Past 30 Days:
2,786
All Time:
58,906
Comments: 97
95 comments on steps, 2 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the front case on a Sony PlayStation 5 DualSense controller.
Note: This guide is for DualSense controllers with an FCC ID ending in 1. Check the back of your controller to verify your model. If yours ends in A, there will be differences in the internal design.
    1. Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Front Case Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Front Case Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Front Case Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. Sony DualSense Controller Front Case Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement: step 9, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Front Case Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Front Case Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. Sony DualSense Controller Front Case Replacement: step 11, image 1 of 3 Sony DualSense Controller Front Case Replacement: step 11, image 2 of 3 Sony DualSense Controller Front Case Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. Sony DualSense Controller Front Case Replacement: step 12, image 1 of 3 Sony DualSense Controller Front Case Replacement: step 12, image 2 of 3 Sony DualSense Controller Front Case Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. Sony DualSense Controller Front Case Replacement: step 13, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Front Case Replacement, Disconnect the battery: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the battery: step 16, image 2 of 2
      • Lift the battery straight out of the battery bracket.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the lower microphone: step 17, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the lower microphone: step 17, image 2 of 2
      Buy
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Remove the battery bracket: step 18, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the battery bracket: step 18, image 2 of 2
      • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement: step 19, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 19, image 2 of 2
      • Lift the battery bracket out of the motherboard.
      Ask FixBot
    4. Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: step 20, image 1 of 2 Sony DualSense Controller Front Case Replacement, Disconnect the right trigger assembly: step 20, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      • Do not completely remove the ribbon cable yet.
      Ask FixBot
    5. Sony DualSense Controller Front Case Replacement: step 21, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 21, image 2 of 2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      • Remove the ribbon cable.
      Ask FixBot
    6. Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: step 22, image 1 of 2 Sony DualSense Controller Front Case Replacement, Disconnect the left trigger assembly: step 22, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      Ask FixBot
    7. Sony DualSense Controller Front Case Replacement: step 23, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 23, image 2 of 2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      Ask FixBot
    8. Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: step 24, image 1 of 2 Sony DualSense Controller Front Case Replacement, Disconnect the upper microphone: step 24, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
      Ask FixBot
    9. Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: step 25, image 1 of 2 Sony DualSense Controller Front Case Replacement, Disconnect the touchpad: step 25, image 2 of 2
      • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
      Ask FixBot
    10. Sony DualSense Controller Front Case Replacement, Lift out the motherboard: step 26, image 1 of 3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: step 26, image 2 of 3 Sony DualSense Controller Front Case Replacement, Lift out the motherboard: step 26, image 3 of 3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
      • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the light guide: step 27, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the light guide: step 27, image 2 of 2
      • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement: step 28, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 28, image 2 of 2
      Buy
      • Use a pair of tweezers or your fingers to remove the light guide bracket.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement: step 29, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 29, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the light guide.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the speaker: step 30, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the speaker: step 30, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the speaker: step 30, image 3 of 3
      Buy
      • Use a pair of tweezers to remove the speaker from the midframe.
      • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Remove the midframe: step 31, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the midframe: step 31, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement: step 32, image 1 of 3 Sony DualSense Controller Front Case Replacement: step 32, image 2 of 3 Sony DualSense Controller Front Case Replacement: step 32, image 3 of 3
      • Carefully lift the midframe and motherboard up and out of the front case.
      • Be careful not to strain the vibrator motor wires.
      • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the touchpad: step 33, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the touchpad: step 33, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement: step 34, image 1 of 3 Sony DualSense Controller Front Case Replacement: step 34, image 2 of 3 Sony DualSense Controller Front Case Replacement: step 34, image 3 of 3
      • Lift the touchpad bracket straight up off the front case.
      • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement: step 35, image 1 of 1
      • Lift the front case up off of the touchpad.
      Ask FixBot
    1. Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: step 36, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: step 36, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the conductive silicone rubber: step 36, image 3 of 3
      Buy
      • Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
      • The buttons are resting loose in the front case.
      Ask FixBot
    2. Sony DualSense Controller Front Case Replacement, Remove the buttons: step 37, image 1 of 1
      • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
      Ask FixBot
    3. Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: step 38, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the touchpad bezel: step 38, image 2 of 2
      • Use your fingers to remove the touchpad bezel from the front case.
      Ask FixBot
    4. Sony DualSense Controller Front Case Replacement: step 39, image 1 of 2 Sony DualSense Controller Front Case Replacement: step 39, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the rubber insulation pad from the front case.
      Ask FixBot
    5. Sony DualSense Controller Front Case Replacement, Remove the upper microphone: step 40, image 1 of 2 Sony DualSense Controller Front Case Replacement, Remove the upper microphone: step 40, image 2 of 2
      • Use a pair of tweezers or your fingers to remove the upper microphone from the front case.
      • Feed the microphone ribbon cable out carefully—the pull tab may catch on the front case.
      Ask FixBot
    6. Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: step 41, image 1 of 3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: step 41, image 2 of 3 Sony DualSense Controller Front Case Replacement, Remove the microphone mute button: step 41, image 3 of 3
      • Use your fingers to lightly pinch the plastic clip securing the microphone mute button to the front case and remove it.
      Ask FixBot
    7. Sony DualSense Controller Front Case Replacement: step 42, image 1 of 1
      • Only the front case remains.
      Ask FixBot
27 other people completed this guide.
Author
with
Sam Omiotek
101,862 Reputation
289 Guides authored
2 Guide Comments
need an update for the “a” variant (cfi-zct1w a)
this guide works for it up until a point (the touchpad), the a variant only has 1 screw instead of two and i couldn’t get the touchpad itself removed from it’s bracket (steps 30/31)
also the “a” variant is missing the light guide bracket (step 25)
name nameson - Reply Share
Two broken controllers became a working one. I had a small discrepancy with touchpad but figured it out. Thanks for the guide.
Dmytro Y. - Reply Share
Past 24 Hours: 138
Past 7 Days: 740
Past 30 Days: 2,786
All Time: 58,906
