Up to 20% off select tools
Sony DualSense Controller Battery Replacement
Views: 268K
View statistics:
Past 24 Hours:
465
Past 7 Days:
3,460
Past 30 Days:
11,270
All Time:
268,480
Comments: 68
48 comments on steps, 20 guide comments.
Go to guide comments
Completed: 129
129 people have marked this guide "completed." Will you be next?
Favorites: 24
24 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace the battery on a Sony PlayStation 5 DualSense controller.
Note: This guide is for DualSense controllers with an FCC ID ending in 1. Check the back of your controller to verify your model. If yours ends in A, there will be differences in the internal design, but you can still use this guide.
If your battery is swollen, take appropriate precautions.
For optimal performance, after completing this guide, calibrate your newly installed battery.
    1. Sony DualSense Controller Battery Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 Sony DualSense Controller Battery Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      Ask FixBot
    2. Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 Sony DualSense Controller Battery Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    3. Sony DualSense Controller Battery Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 Sony DualSense Controller Battery Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      Ask FixBot
    4. Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 Sony DualSense Controller Battery Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      Ask FixBot
    5. Sony DualSense Controller Battery Replacement, Remove the middle trim: step 5, image 1 of 3 Sony DualSense Controller Battery Replacement, Remove the middle trim: step 5, image 2 of 3 Sony DualSense Controller Battery Replacement, Remove the middle trim: step 5, image 3 of 3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      Ask FixBot
    1. Sony DualSense Controller Battery Replacement, Remove the L1 button: step 6, image 1 of 3 Sony DualSense Controller Battery Replacement, Remove the L1 button: step 6, image 2 of 3 Sony DualSense Controller Battery Replacement, Remove the L1 button: step 6, image 3 of 3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      Ask FixBot
    2. Sony DualSense Controller Battery Replacement, Remove the R1 button: step 7, image 1 of 3 Sony DualSense Controller Battery Replacement, Remove the R1 button: step 7, image 2 of 3 Sony DualSense Controller Battery Replacement, Remove the R1 button: step 7, image 3 of 3
      • Repeat the previous step to remove the R1 button.
      Ask FixBot
    1. Sony DualSense Controller Battery Replacement, Remove the rear case screws: step 8, image 1 of 2 Sony DualSense Controller Battery Replacement, Remove the rear case screws: step 8, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      Ask FixBot
    2. Sony DualSense Controller Battery Replacement: step 9, image 1 of 2 Sony DualSense Controller Battery Replacement: step 9, image 2 of 2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      Ask FixBot
    3. Sony DualSense Controller Battery Replacement, Separate the rear case: step 10, image 1 of 3 Sony DualSense Controller Battery Replacement, Separate the rear case: step 10, image 2 of 3 Sony DualSense Controller Battery Replacement, Separate the rear case: step 10, image 3 of 3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      Ask FixBot
    4. Sony DualSense Controller Battery Replacement: step 11, image 1 of 3 Sony DualSense Controller Battery Replacement: step 11, image 2 of 3 Sony DualSense Controller Battery Replacement: step 11, image 3 of 3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      Ask FixBot
    5. Sony DualSense Controller Battery Replacement: step 12, image 1 of 3 Sony DualSense Controller Battery Replacement: step 12, image 2 of 3 Sony DualSense Controller Battery Replacement: step 12, image 3 of 3
      • Repeat the previous step on the right edge to release its clips.
      Ask FixBot
    6. Sony DualSense Controller Battery Replacement: step 13, image 1 of 2 Sony DualSense Controller Battery Replacement: step 13, image 2 of 2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      Ask FixBot
    1. Sony DualSense Controller Battery Replacement, Remove the rear case: step 14, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Sony DualSense Controller Battery Replacement, Disconnect the battery: step 15, image 1 of 2 Sony DualSense Controller Battery Replacement, Disconnect the battery: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      Ask FixBot
    2. Sony DualSense Controller Battery Replacement, Remove the battery: step 16, image 1 of 2 Sony DualSense Controller Battery Replacement, Remove the battery: step 16, image 2 of 2
      • Lift the battery straight out of the battery bracket.
      Ask FixBot
129 other people completed this guide.
Author
with
Sam Omiotek
101,875 Reputation
289 Guides authored
20 Guide Comments
Is there a better battery that can be used rather than the standard battery? This controller dies so fast that I don’t bother disconnecting it ever. I’m pretty sure that’s bad, but It’s frustrating having it die midgame in my second game.
Anthony Ramirez - Reply Share
Yes. You can purchase a 2000mah battery replacement. It’s not much of a difference, but lowering your led settings and controller vibration also works wonders for prolonging the battery life.
John Jevitz - Reply Share
Any chance you could figure out why the %#*@ thing won't work USB powered with no battery? I shouldn't have to keep replacing a battery when I don't actually want to play wireless.
NoLife - Reply Share
@NoLife
If you bridge the pins for the red and white battery wires, the controller will power on properly without a battery. This will be easiest with a soldering iron.
Amboy Scout - Reply Share
I need a new battery for my Dualsense controller, Sony is saying to just buy a new one while I'm not gonna take broken for a answer. So if anyone knows a reliable site where I can get a battery replacement for my dualsense, do recommend
Diaper Fixer 360 - Reply Share
Past 24 Hours: 465
Past 7 Days: 3,460
Past 30 Days: 11,270
All Time: 268,480
