Sony Dream Machine ICF-C717PJ Screen Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
11
Past 30 Days:
69
All Time:
1,829
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
If the display on the Sony Dream Machine is not showing up properly or has any similar issues, the display monitor may need to be adjusted. Please see the Sony Dream Machine ICF-C717PJ Troubleshooting page: Sony Dream Machine ICF-C717PJ to eliminate other possible issues before tampering with the screen/display.
Tools
    1. Sony Dream Machine ICF-C717PJ Screen Replacement, Screen: step 1, image 1 of 1
      • Using a Phillips #0 screwdriver unscrew the three screws that connect the back panel to the device.
      Ask FixBot
    2. Sony Dream Machine ICF-C717PJ Screen Replacement: step 2, image 1 of 1
      • Using a thin flat tool, pry off the panel on the back of the device.
      Ask FixBot
    3. Sony Dream Machine ICF-C717PJ Screen Replacement: step 3, image 1 of 2 Sony Dream Machine ICF-C717PJ Screen Replacement: step 3, image 2 of 2
      • Unscrew the two screws connecting the motor board to the device.
      • Gently remove the motherboard from the device to gain access to the screen.
      Ask FixBot
    4. Sony Dream Machine ICF-C717PJ Screen Replacement: step 4, image 1 of 2 Sony Dream Machine ICF-C717PJ Screen Replacement: step 4, image 2 of 2
      • Flip the device around so that the display is facing you. Gently push the display towards the inside of the device.
      • Disconnect the display cable from the motherboard and reconnect the display cable for the new display.
      • After connecting the new display push it firmly in place so that the display panel is properly aligned with the cutout for the display. When correctly locked in place the display panel should not move around.
      Ask FixBot
Gurleen Powar
376 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 69
All Time: 1,829
