Sony DVP-NS325 Power Cable Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
56
All Time:
437
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The cable is the power supply for the DVD player it is used to give power to every component and is an external cord that stays outside the DVD Player. Make sure to unplug the cable before beginning.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 1 of 3 Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 2 of 3 Sony DVP-NS325 Power Cable Replacement, Outer Case: step 1, image 3 of 3
      • Use a Phillips screwdriver to unscrew the five screws.
      Ask FixBot
    2. Sony DVP-NS325 Power Cable Replacement: step 2, image 1 of 3 Sony DVP-NS325 Power Cable Replacement: step 2, image 2 of 3 Sony DVP-NS325 Power Cable Replacement: step 2, image 3 of 3
      • Use the Philips screwdriver to remove the screws located on the sides and the back.
      • Not shown are the right side screw and the middle screw.
      Ask FixBot
    3. Sony DVP-NS325 Power Cable Replacement: step 3, image 1 of 1
      • Use a spudger to separate the case from the chassis.
      • Remove the case.
      Ask FixBot
    1. Sony DVP-NS325 Power Cable Replacement, Power Cable: step 4, image 1 of 2 Sony DVP-NS325 Power Cable Replacement, Power Cable: step 4, image 2 of 2
      • Unscrew all screws using a Phillips screwdriver removing the outer case to access the power cable.
      Ask FixBot
    2. Sony DVP-NS325 Power Cable Replacement: step 5, image 1 of 2 Sony DVP-NS325 Power Cable Replacement: step 5, image 2 of 2
      • Using a finger, press down on the clip to remove the connector for the cable.
      Ask FixBot
    3. Sony DVP-NS325 Power Cable Replacement: step 6, image 1 of 1
      • Using two fingers, press in both the top and bottom clips to release the holder for the power cable to remove the cable completely.
      Ask FixBot
    4. Sony DVP-NS325 Power Cable Replacement: step 7, image 1 of 1
      • Pull the cable out of the case to fully replace the cable.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 56
All Time: 437
