Sony DVP-NS325 Optical Drive Replacement
    1. Sony DVP-NS325 Optical Drive Replacement, Outer Case: step 1, image 1 of 3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: step 1, image 2 of 3 Sony DVP-NS325 Optical Drive Replacement, Outer Case: step 1, image 3 of 3
      • Use a Phillips screwdriver to unscrew the five screws.
      Ask FixBot
    2. Sony DVP-NS325 Optical Drive Replacement: step 2, image 1 of 3 Sony DVP-NS325 Optical Drive Replacement: step 2, image 2 of 3 Sony DVP-NS325 Optical Drive Replacement: step 2, image 3 of 3
      • Use the Philips screwdriver to remove the screws located on the sides and the back.
      • Not shown are the right side screw and the middle screw.
      Ask FixBot
    3. Sony DVP-NS325 Optical Drive Replacement: step 3, image 1 of 1
      • Use a spudger to separate the case from the chassis.
      • Remove the case.
      Ask FixBot
    1. Sony DVP-NS325 Optical Drive Replacement, Optical Drive: step 4, image 1 of 3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: step 4, image 2 of 3 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: step 4, image 3 of 3
      • The Location of the three screws holding the CD reader in place.
      Ask FixBot
    2. Sony DVP-NS325 Optical Drive Replacement: step 5, image 1 of 1
      • Use a Phillips screwdriver to remove all three screws holding the CD reader in position.
      • Two screws not shown.
      Ask FixBot
    3. Sony DVP-NS325 Optical Drive Replacement: step 6, image 1 of 2 Sony DVP-NS325 Optical Drive Replacement: step 6, image 2 of 2
      • Disconnect all of the optical drive motherboard connections.
      Ask FixBot
    4. Sony DVP-NS325 Optical Drive Replacement: step 7, image 1 of 3 Sony DVP-NS325 Optical Drive Replacement: step 7, image 2 of 3 Sony DVP-NS325 Optical Drive Replacement: step 7, image 3 of 3
      • Lift the four retention clips holding the face of the DVD player in place.
      • Two clips are not shown, left and bottom right side clips.
      Ask FixBot
    5. Sony DVP-NS325 Optical Drive Replacement: step 8, image 1 of 1
      • Remove the front face of the DVD player by pulling it away from the device.
      Ask FixBot
    6. Sony DVP-NS325 Optical Drive Replacement: step 9, image 1 of 1
      • Remove the optical drive.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 38
All Time: 479
