Sony DVP-NS325 Motherboard Replacement
  1. Sony DVP-NS325 Motherboard Replacement, Outer Case: step 1, image 1 of 3 Sony DVP-NS325 Motherboard Replacement, Outer Case: step 1, image 2 of 3 Sony DVP-NS325 Motherboard Replacement, Outer Case: step 1, image 3 of 3
    • Use a Phillips screwdriver to unscrew the five screws.
    Ask FixBot
  2. Sony DVP-NS325 Motherboard Replacement: step 2, image 1 of 3 Sony DVP-NS325 Motherboard Replacement: step 2, image 2 of 3 Sony DVP-NS325 Motherboard Replacement: step 2, image 3 of 3
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
    Ask FixBot
  3. Sony DVP-NS325 Motherboard Replacement: step 3, image 1 of 1
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
    Ask FixBot
  4. Sony DVP-NS325 Motherboard Replacement, Motherboard: step 4, image 1 of 3 Sony DVP-NS325 Motherboard Replacement, Motherboard: step 4, image 2 of 3 Sony DVP-NS325 Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Remove all cables that are connected to the motherboard by pulling upwards from the motherboard.
    • Grip as close to the connectors as possible. Avoid pulling on the wires/ribbon cables.
    Ask FixBot
  5. Sony DVP-NS325 Motherboard Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove all screws located in the 4 corners of the motherboard.
    Ask FixBot
  6. Sony DVP-NS325 Motherboard Replacement: step 6, image 1 of 1
    • Pull the motherboard up and out of the device.
    Ask FixBot
2 other people completed this guide.
madison mathis
360 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 28
All Time: 471
