Sony DVP-FX97 Traverse Assembly Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
66
All Time:
317
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the traverse assembly in your Sony DVP-FX97.
For your safety, discharge the battery before disassembling. This reduces the risk of a fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Parts
Tools
  • Spudger
    4.9
  • Tweezers
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. Sony DVP-FX97 Traverse Assembly Replacement, Traverse Assembly: step 1, image 1 of 1
      • Set the DVP on a stable surface.
      Ask FixBot
    2. Sony DVP-FX97 Traverse Assembly Replacement: step 2, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two black 5.8mm screws.
      Ask FixBot
    3. Sony DVP-FX97 Traverse Assembly Replacement: step 3, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 3, image 2 of 2
      • Use the Phillips #00 screwdriver to remove the seven black 5.8mm screws.
      Ask FixBot
    4. Sony DVP-FX97 Traverse Assembly Replacement: step 4, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 4, image 2 of 2
      • Remove the four black pads with a spudger.
      • Use the Phillips #00 screwdriver to remove the four aluminum 2.8mm screws.
      Ask FixBot
    5. Sony DVP-FX97 Traverse Assembly Replacement: step 5, image 1 of 1
      • When removing the top, be careful of the ribbon cable connecting the top and bottom.
      • Use a spudger to lift the top off.
      Ask FixBot
    6. Sony DVP-FX97 Traverse Assembly Replacement: step 6, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 6, image 2 of 2
      • Use the spudger to flip the clip that holds down the ribbon cable and disconnect it from the motherboard.
      Ask FixBot
    7. Sony DVP-FX97 Traverse Assembly Replacement: step 7, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 7, image 2 of 2
      • Use tweezers to disconnect the ribbon cable from the traverse assembly.
      Ask FixBot
    8. Sony DVP-FX97 Traverse Assembly Replacement: step 8, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 8, image 2 of 2
      • Disconnect the pin-connector carefully from the traverse assembly.
      Ask FixBot
    9. Sony DVP-FX97 Traverse Assembly Replacement: step 9, image 1 of 2 Sony DVP-FX97 Traverse Assembly Replacement: step 9, image 2 of 2
      • Remove the traverse assembly by lifting.
      Ask FixBot
Paul Chapa
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 66
All Time: 317
