Sony DSC-RX10M3 Back and Right Panel Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
89
All Time:
2,136
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is an important pre-requisite that is required to replace the Sony DSC-RX10M3 LCD and viewfinder. You will find in this guide the important steps required to make sure that you properly remove the back casing which exposes the motherboard of the device.
Tools
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: step 1, image 1 of 1
      • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
      Ask FixBot
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: step 2, image 1 of 3 Sony DSC-RX10M3 Back and Right Panel Replacement: step 2, image 2 of 3 Sony DSC-RX10M3 Back and Right Panel Replacement: step 2, image 3 of 3
      • Remove the battery located at the bottom of the device.
      Ask FixBot
    1. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: step 3, image 1 of 1
      • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
      Ask FixBot
    2. Sony DSC-RX10M3 Back and Right Panel Replacement: step 4, image 1 of 2 Sony DSC-RX10M3 Back and Right Panel Replacement: step 4, image 2 of 2
      • Remove the two 0.7mm screws that secure the right side of the camera.
      • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
      Ask FixBot
    3. Sony DSC-RX10M3 Back and Right Panel Replacement: step 5, image 1 of 2 Sony DSC-RX10M3 Back and Right Panel Replacement: step 5, image 2 of 2
      • Gently pull off the plastic eye guard.
      Ask FixBot
    4. Sony DSC-RX10M3 Back and Right Panel Replacement: step 6, image 1 of 2 Sony DSC-RX10M3 Back and Right Panel Replacement: step 6, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
      • Use a plastic opening tool to detach the back panel of the camera.
      Ask FixBot
    5. Sony DSC-RX10M3 Back and Right Panel Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • This is a tight spot; make sure you use minimal force when removing the cover.
      • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
      Ask FixBot
    6. Sony DSC-RX10M3 Back and Right Panel Replacement: step 8, image 1 of 1
      • This step is only needed if you wish to remove the right side panel.
      • Use a plastic openeing tool to gently detach the right panel.
      Ask FixBot
3 other people completed this guide.
Salman Hersi
339 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 89
All Time: 2,136
