Up to 20% off select tools
Sony DSC-RX100MA Back Cover Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
30
Past 30 Days:
127
All Time:
4,679
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Need to clean the inside of the camera? Start by taking off the back cover.
    1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement, Back Cover: step 1, image 3 of 3
      • Remove battery by sliding the tab to open the cover
      Ask FixBot
    2. Sony DSC-RX100MA Back Cover Replacement: step 2, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 2, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 2, image 3 of 3
      • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
      • All screws in the camera can be removed with the PH 0 driver head.
      Ask FixBot
    3. Sony DSC-RX100MA Back Cover Replacement: step 3, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 3, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 3, image 3 of 3
      • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
      • Remove the marked 2.5 mm screws with the screwdriver
      Ask FixBot
    4. Sony DSC-RX100MA Back Cover Replacement: step 4, image 1 of 2 Sony DSC-RX100MA Back Cover Replacement: step 4, image 2 of 2
      • Using the plastic opening tools, carefully pry off the bottom plate.
      • Do not pull too hard as you may break the plastic casing.
      Ask FixBot
    5. Sony DSC-RX100MA Back Cover Replacement: step 5, image 1 of 3 Sony DSC-RX100MA Back Cover Replacement: step 5, image 2 of 3 Sony DSC-RX100MA Back Cover Replacement: step 5, image 3 of 3
      • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
      • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
      Ask FixBot
    6. Sony DSC-RX100MA Back Cover Replacement: step 6, image 1 of 2 Sony DSC-RX100MA Back Cover Replacement: step 6, image 2 of 2
      • Remove the back cover
      Ask FixBot
2 other people completed this guide.
Author
with
KC Egger
315 Reputation
2 Guides authored
Cal Poly, Team 21-1, Maness Winter 2017 Member of Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Members
60 Guides authored
1 Guide Comment
Hi! Two of the 1mm screws fell out of my camera from behind the display, where can I find new ones? I keep checking amazon and its kits of 750pcs+ and they don't seem like the right 1mm screws. Do you know where I can get some?
Victoria Gallardo - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 127
All Time: 4,679
