Sony DCR-DVD 108 LCD Screen Replacement
  1. Sony DCR-DVD 108 LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
    Ask FixBot
  2. Sony DCR-DVD 108 LCD Screen Replacement: step 2, image 1 of 1
    • Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
    Ask FixBot
  3. Sony DCR-DVD 108 LCD Screen Replacement: step 3, image 1 of 1
    • Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
    Ask FixBot
  4. Sony DCR-DVD 108 LCD Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Slowly pry apart the covers using a plastic spudger.
    • Be sure to disconnect the ZIF connector holding the ribbon cable in place. To do this, use a spudger to flip the black tab up, and pull the cable out with tweezers.
    • This photo shows a torn ribbon cable. Be sure to disconnect the ribbon cable before fully removing the LCD cover, to avoid damage to the device.
    Ask FixBot
Elijah DeWolf
616 Reputation
5 Guides authored
USF Tampa, Team 7-6, Cheng Spring 2016 Member of USF Tampa, Team 7-6, Cheng Spring 2016
USFT-CHENG-S16S7G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 53
All Time: 1,501
