Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: step 1, image 1 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: step 1, image 2 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: step 1, image 3 of 3
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
    Ask FixBot
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 2, image 1 of 1
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
    Ask FixBot
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 3, image 1 of 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 3, image 2 of 2
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
    Ask FixBot
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 4, image 1 of 1
    • Now take the control wheel board out with your hand.
    Ask FixBot
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 5, image 1 of 1
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
    Ask FixBot
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 6, image 2 of 2
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
    Ask FixBot
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 7, image 1 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 7, image 2 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 7, image 3 of 3
    • Using your finger open take off the three zifs.
    Ask FixBot
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 8, image 2 of 2
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
    Ask FixBot
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 9, image 1 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 9, image 2 of 3 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 9, image 3 of 3
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
    Ask FixBot
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: step 10, image 2 of 2
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
    Ask FixBot
4 other people completed this guide.
Matt Garthwaite
125 Reputation
1 Guide authored
IUPUI, Team S1-G1, Wilson Summer 2017 Member of IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 49
All Time: 2,391
