Sony Cyber-shot DSC-W570 LCD Screen Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
147
All Time:
2,485
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
This is a guide to replace dead pixels, cracked screens, and malfunctioning button terminals.
Tools
    1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, Case Cover: step 1, image 1 of 1
      • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
      • Remove these two screws using a Philips #00 screwdriver
      • Make sure the battery compartment door is in lock position.
      Ask FixBot
    2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 2, image 1 of 1
      • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
      • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
      • Keep all screws on stable surface to not loose them
      Ask FixBot
    3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 3, image 1 of 1
      • Turn the camera on its right side making sure it is facing upwards
      • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
      Ask FixBot
    4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 4, image 2 of 2
      • Face the device with the camera lens facing upwards
      • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
      • Gently pry off each corner of the cover to remove it
      • Once all corners are pried off, gently lift off the cover and place it on the side
      Ask FixBot
    5. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 5, image 1 of 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 5, image 2 of 2
      • Flip the device, making sure the screen is facing upwards
      • The back case should now be visible and ready to remove
      • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
      • Gently lift off the entire back cover and place it on the side
      Ask FixBot
    1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, LCD Screen: step 6, image 1 of 1
      • Taking off the previous cover will reveal the two cables connecting the LCD screen to the motherboard below the screen.
      Ask FixBot
    2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 7, image 1 of 1
      • Remove the LCD screen from the side opposite the battery terminals.
      • Watch carefully for the two cords mentioned in the previous step. These will still be connected.
      • The side will flip up as shown in the next step.
      Ask FixBot
    3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 8, image 1 of 1
      • Pull these two cords straight back to disconnect them from the respective housings.
      • Caution: The housing does not need to be moved or adjusted in any way. DO NOT pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
      Ask FixBot
    4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: step 9, image 1 of 1
      • This is what the camera should look like after 2 cords and the screen have been removed.
      • The lens cord is being held to the side for a clearer view.
      Ask FixBot
3 other people completed this guide.
Thomas Plummer
194 Reputation
1 Guide authored
USF Tampa, Team 9-1, Brown Winter 2015 Member of USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 Members
60 Guides authored
2 Guide Comments
And the screen replacement how??
Pau Roqué Robert - Reply Share
do I need glue?
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 147
All Time: 2,485
