Sony Cyber-shot DSC-W55 LCD Screen Replacement
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Battery: step 1, image 2 of 2
      • Slide the battery cover in the direction the arrow points.
      • Pull the battery cover towards you.
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 2, image 2 of 2
      • Flick the blue switch for the battery to pop out.
      • Remove the battery from the camera.
      Ask FixBot
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: step 3, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Back Case: step 3, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
      • Remove that panel.
      • Careful for falling pieces.
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 4, image 2 of 2
      • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
      • Remove the panel.
      Ask FixBot
    3. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 5, image 1 of 1
      • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
      Ask FixBot
    4. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 6, image 2 of 2
      • Gently remove the back cover.
      • It may be a bit stiff, so use some force to remove it. Proceed with caution.
      Ask FixBot
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Front Case: step 7, image 1 of 1
      • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 8, image 1 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 8, image 2 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 8, image 3 of 3
      • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
      • Gently remove the front cover.
      • Put a little force to pop off the case. Proceed with caution.
      Ask FixBot
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: step 9, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement, Lens: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Flip the black secure locks off. Tweezers may be necessary.
      • Detach the two orange cables.
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 10, image 2 of 2
      • Gently pull the lens container out of the camera.
      Ask FixBot
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, Motherboard - First Half: step 11, image 1 of 1
      • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 12, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 12, image 2 of 2
      Buy
      • Remove the two orange cables on the top of the motherboard with tweezers.
      • Lift the motherboard out of its slot.
      Ask FixBot
    3. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 13, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 13, image 2 of 2
      • For the AV port, detach the bottom orange cable.
      • For the LCD screen, detach the top orange cable on the right side of the motherboard.
      • For the motherboard, detach all the orange cables.
      • Careful not to damage the red, white, and black wires when lifting the board.
      Ask FixBot
    1. Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: step 14, image 1 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: step 14, image 2 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement, LCD Screen: step 14, image 3 of 3
      • Verify the orange cables from the motherboard are removed from the LCD screen.
      • Lift the LCD screen off the hinge.
      Ask FixBot
    2. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 15, image 1 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 15, image 2 of 3 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 15, image 3 of 3
      • Verify that the LCD screen is attached to the chip on the back on the camera.
      • Remove the dial from the back of the camera. It pops right off very easily.
      • Remove the screw using a Phillips #00 Screwdriver from the camera.
      Ask FixBot
    3. Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 16, image 1 of 2 Sony Cyber-shot DSC-W55 LCD Screen Replacement: step 16, image 2 of 2
      • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
      • Remove the chip and the LCD screen now from the camera.
      • The chip may need a slight upward tug with a fingernail or tweezer.
      Ask FixBot
5 other people completed this guide.
Eddie Lo
352 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2010 Member of Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 119
All Time: 15,480
