Sony Cyber-shot DSC-W290 casing Replacement
  1. Sony Cyber-shot DSC-W290 casing Replacement, Battery: step 1, image 1 of 1
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
    Ask FixBot
  2. Sony Cyber-shot DSC-W290 casing Replacement: step 2, image 1 of 1
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
    Ask FixBot
  3. Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: step 3, image 1 of 2 Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: step 3, image 2 of 2
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
    Ask FixBot
  4. Sony Cyber-shot DSC-W290 casing Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-W290 casing Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-W290 casing Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
    Ask FixBot
  5. Sony Cyber-shot DSC-W290 casing Replacement: step 5, image 1 of 3 Sony Cyber-shot DSC-W290 casing Replacement: step 5, image 2 of 3 Sony Cyber-shot DSC-W290 casing Replacement: step 5, image 3 of 3
    • Turn the camera so the right side faces you.
    Ask FixBot
  6. Sony Cyber-shot DSC-W290 casing Replacement: step 6, image 1 of 1
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
    Ask FixBot
  7. Sony Cyber-shot DSC-W290 casing Replacement: step 7, image 1 of 2 Sony Cyber-shot DSC-W290 casing Replacement: step 7, image 2 of 2
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
    Ask FixBot
  8. Sony Cyber-shot DSC-W290 casing Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-W290 casing Replacement: step 8, image 2 of 2
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
    Ask FixBot
  9. Sony Cyber-shot DSC-W290 casing Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-W290 casing Replacement: step 9, image 2 of 2
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
    Ask FixBot
  10. Sony Cyber-shot DSC-W290 casing Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-W290 casing Replacement: step 10, image 2 of 2
    • This is what your camera should look like now that you have removed the casing from all sides.
    Ask FixBot
Evan Mayer
336 Reputation
5 Guides authored
Cal Poly, Team 7-54, Amido Fall 2010 Member of Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 57
All Time: 2,455
