Sony Cyber-shot DSC-W150 Image Sensor Replacement
  1. Sony Cyber-shot DSC-W150 Image Sensor Replacement, Back Casing: step 1, image 1 of 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
    Ask FixBot
  2. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 2, image 1 of 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
    Ask FixBot
  3. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 3, image 1 of 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
    Ask FixBot
  4. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 4, image 1 of 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
    Ask FixBot
  5. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 5, image 1 of 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
    Ask FixBot
  6. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 6, image 1 of 1
    • After detaching the back cover, carefully pull it off.
    Ask FixBot
  7. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 7, image 1 of 1
    • The back cover should now be separated from the camera.
    Ask FixBot
  8. Sony Cyber-shot DSC-W150 Image Sensor Replacement, Front Casing: step 8, image 1 of 1
    • Keep track of the small screws that you remove.
    • Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
    Ask FixBot
  9. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 9, image 1 of 1
    • Remove the two screws at the top of the camera casing.
    Ask FixBot
  10. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 10, image 1 of 1
    • After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
    Ask FixBot
  11. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 11, image 1 of 1
    • After popping open the plastic piece, there is a screw that needs to be removed.
    • Remove the screw connecting the front casing to the electrical components.
    Ask FixBot
  12. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 12, image 1 of 1
    • On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
    • Be cautious not to break the fragile pieces or scratch the LCD screen.
    Ask FixBot
  13. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 13, image 1 of 1
    • Remove the two screws connecting the front casing to the electrical components using a screwdriver.
    Ask FixBot
  14. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 14, image 1 of 1
    • Gently loosen the front casing by gently using your fingers to pull it apart.
    • Be cautious not to scratch any of the exposed electrical components.
    Ask FixBot
  15. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 15, image 1 of 1
    • Fully remove the front casing from the camera and set it aside.
    Ask FixBot
  16. Ask FixBot
    • Remove the two silver screws and two black screw holding the image sensor in place.
    Ask FixBot
  17. Sony Cyber-shot DSC-W150 Image Sensor Replacement: step 18, image 1 of 1
    Tool used on this step:
    Buy
    • Using a spudger, wedge the flat tipped end between the black bar and the circuit board.
    • Carefully lift the black bar into the vertical position.
    • Repeat first two bullet points for the circuit board port directly to the left of the one shown in this picture.
    • Use tweezers to carefully pull the electrical ribbons from the circuit board ports.
    Ask FixBot
    • Carefully remove image sensor and replace with new image sensor.
    Ask FixBot
2 other people completed this guide.
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 6,641
