Sony Cyber-shot DSC-W150 Front Casing Replacement
  1. Sony Cyber-shot DSC-W150 Front Casing Replacement, Back Casing: step 1, image 1 of 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
    Ask FixBot
  2. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 2, image 1 of 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
    Ask FixBot
  3. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 3, image 1 of 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
    Ask FixBot
  4. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 4, image 1 of 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
    Ask FixBot
  5. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 5, image 1 of 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
    Ask FixBot
  6. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 6, image 1 of 1
    • After detaching the back cover, carefully pull it off.
    Ask FixBot
  7. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 7, image 1 of 1
    • The back cover should now be separated from the camera.
    Ask FixBot
  8. Sony Cyber-shot DSC-W150 Front Casing Replacement, Front Casing: step 8, image 1 of 1
    • Keep track of the small screws that you remove.
    • Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
    Ask FixBot
  9. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 9, image 1 of 1
    • Remove the two screws at the top of the camera casing.
    Ask FixBot
  10. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 10, image 1 of 1
    • After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
    Ask FixBot
  11. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 11, image 1 of 1
    • After popping open the plastic piece, there is a screw that needs to be removed.
    • Remove the screw connecting the front casing to the electrical components.
    Ask FixBot
  12. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 12, image 1 of 1
    • On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
    • Be cautious not to break the fragile pieces or scratch the LCD screen.
    Ask FixBot
  13. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 13, image 1 of 1
    • Remove the two screws connecting the front casing to the electrical components using a screwdriver.
    Ask FixBot
  14. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 14, image 1 of 1
    • Gently loosen the front casing by gently using your fingers to pull it apart.
    • Be cautious not to scratch any of the exposed electrical components.
    Ask FixBot
  15. Sony Cyber-shot DSC-W150 Front Casing Replacement: step 15, image 1 of 1
    • Fully remove the front casing from the camera and set it aside.
    Ask FixBot
5 other people completed this guide.
Julio Maravilla
191 Reputation
1 Guide authored
Cal Poly, Team 33-73, Johann Spring 2010 Member of Cal Poly, Team 33-73, Johann Spring 2010
CPSU-JOHANN-S10S33G73
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 43
All Time: 6,689
