Sony Cyber-shot DSC-W150 Back Casing Replacement
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: step 1, image 1 of 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
    Ask FixBot
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 2, image 1 of 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
    Ask FixBot
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 3, image 1 of 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
    Ask FixBot
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 4, image 1 of 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
    Ask FixBot
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 5, image 1 of 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
    Ask FixBot
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 6, image 1 of 1
    • After detaching the back cover, carefully pull it off.
    Ask FixBot
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: step 7, image 1 of 1
    • The back cover should now be separated from the camera.
    Ask FixBot
4 other people completed this guide.
iRobot
1 Reputation
636 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 40
All Time: 5,607
