Sony Cyber-shot DSC-TX7 LCD Screen Replacement
  1. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • The battery compartment is located on the bottom of camera.
    • Move the slider from the 'lock' position to the 'open' position.
    Ask FixBot
  2. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 2, image 3 of 3
    • Battery not shown.
    • Pull battery from compartment.
    • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
    • Shut compartment door.
    • Move the slider back to the 'lock' position.
    Ask FixBot
  3. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Front Cover: step 3, image 1 of 1
    • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
    Ask FixBot
  4. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 4, image 3 of 3
    • The 4 mm length screws are located on each side and on the bottom of the camera.
    • 2 screws on each side (4 total).
    • 2 screws on bottom.
    Ask FixBot
  5. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 5, image 1 of 1
    • Gently pry around the front cover using the plastic opening tool.
    • Carefully separate front cover from body of camera.
    Ask FixBot
  6. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 6, image 1 of 1
    • The front cover is now removed from the camera and the internal hardware is now visible.
    • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
    Ask FixBot
  7. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, Back Cover: step 7, image 1 of 1
    • This is the camera with the front cover unscrewed and partially removed.
    Ask FixBot
  8. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 8, image 2 of 2
    • Peel the black sticker from the motherboard.
    • Locate the connection ribbon between the front cover and the body of the device.
    Ask FixBot
  9. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 9, image 2 of 2
    • Pull the ribbon out of the connection port so that they are completely disconnected.
    Ask FixBot
  10. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 10, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 10, image 2 of 2
    • Use the plastic opening tool to separate the back cover from the inner hardware.
    • Continue until back cover can be pulled away from inner hardware.
    Ask FixBot
  11. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 11, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 11, image 2 of 2
    • Remove the back cover so that the back cover is now completely separate from the body of the device.
    Ask FixBot
  12. Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: step 12, image 1 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: step 12, image 2 of 3 Sony Cyber-shot DSC-TX7 LCD Screen Replacement, LCD Screen: step 12, image 3 of 3
    • Pry the LCD screen using the spudger from the back of the camera.
    • Flip screen away from body of device.
    Ask FixBot
  13. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 13, image 1 of 1
    • Lay the camera as shown, so that screen and camera body are next to each other, connected by the yellow ribbon.
    • Peel back the black sticker covering the motherboard.
    Ask FixBot
  14. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 14, image 1 of 2 Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 14, image 2 of 2
    • Locate the yellow ribbon's connection port.
    • Flip the black bar holding the ribbon in place toward the body of the camera.
    Ask FixBot
  15. Sony Cyber-shot DSC-TX7 LCD Screen Replacement: step 15, image 1 of 1
    • Pull the yellow ribbon out of the connection port.
    • The LCD screen is now separate from the body of the device.
    Ask FixBot
Leslie Mundell
414 Reputation
4 Guides authored
2 Guide Comments
Very nice guide... Could you provide a dealer where it is possible to find spare parts for Sony cameras?
serhatturkmen - Reply Share
where can I find a new screen?
John Price - Reply Share
Past 24 Hours: 0
Past 7 Days: 28
Past 30 Days: 81
All Time: 2,651
