Sony Cyber-shot DSC-TX7 Front Cover Replacement
    1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-TX7 Front Cover Replacement, Battery: step 1, image 2 of 2
      • The battery compartment is located on the bottom of camera.
      • Move the slider from the 'lock' position to the 'open' position.
      Ask FixBot
    2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 2, image 1 of 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 2, image 2 of 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 2, image 3 of 3
      • Battery not shown.
      • Pull battery from compartment.
      • Insert newly charged battery into compartment, as shown in diagram (located in compartment).
      • Shut compartment door.
      • Move the slider back to the 'lock' position.
      Ask FixBot
    1. Sony Cyber-shot DSC-TX7 Front Cover Replacement, Front Cover: step 3, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the 4mm length screws. There are 6 screws total.
      Ask FixBot
    2. Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 4, image 1 of 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 4, image 2 of 3 Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 4, image 3 of 3
      • The 4 mm length screws are located on each side and on the bottom of the camera.
      • 2 screws on each side (4 total).
      • 2 screws on bottom.
      Ask FixBot
    3. Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 5, image 1 of 1
      • Gently pry around the front cover using the plastic opening tool.
      • Carefully separate front cover from body of camera.
      Ask FixBot
    4. Sony Cyber-shot DSC-TX7 Front Cover Replacement: step 6, image 1 of 1
      • The front cover is now removed from the camera and the internal hardware is now visible.
      • They front cover will still be connected by a ribbon. Be careful not to break the ribbon.
      Ask FixBot
Leslie Mundell
414 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 40
All Time: 752
