Sony Cyber-shot DSC-T1 LCD Replacement
  1. Sony Cyber-shot DSC-T1 LCD Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement, Battery: step 1, image 2 of 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
    Ask FixBot
  2. Sony Cyber-shot DSC-T1 LCD Replacement: step 2, image 1 of 1
    • Remove the battery from the door that you opened in the previous step.
    Ask FixBot
  3. Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 1 of 3 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 2 of 3 Sony Cyber-shot DSC-T1 LCD Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: step 3, image 3 of 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
    Ask FixBot
  4. Sony Cyber-shot DSC-T1 LCD Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement: step 4, image 2 of 2
    • Use hands to gently pry the front casing away from the camera.
    Ask FixBot
  5. Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: step 5, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement, CCD Sensor Module: step 5, image 2 of 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
    Ask FixBot
  6. Sony Cyber-shot DSC-T1 LCD Replacement: step 6, image 1 of 1
    • Grasp the CCD Sensor Module and remove it.
    Ask FixBot
  7. Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: step 7, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement, Motherboard Assembly: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to slide the white piece on the back of the back cover to the right.
    • This will dislodge the white piece, allowing you to remove it from the back cover.
    Ask FixBot
  8. Sony Cyber-shot DSC-T1 LCD Replacement: step 8, image 1 of 1
    • Remove the ribbon cables from these two ZIF connectors.
    Ask FixBot
  9. Sony Cyber-shot DSC-T1 LCD Replacement: step 9, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement: step 9, image 2 of 2
    • Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
    • Remove the ZIF connectors from the clamp on the left end of the top piece.
    • The motherboard assembly is now separated from the back cover.
    Ask FixBot
  10. Sony Cyber-shot DSC-T1 LCD Replacement, LCD: step 10, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement, LCD: step 10, image 2 of 2
    • Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
    Ask FixBot
  11. Sony Cyber-shot DSC-T1 LCD Replacement: step 11, image 1 of 2 Sony Cyber-shot DSC-T1 LCD Replacement: step 11, image 2 of 2
    • Remove the back frame from the LCD assembly.
    • Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
    Ask FixBot
  12. Sony Cyber-shot DSC-T1 LCD Replacement: step 12, image 1 of 1
    • Pull the tape off that holds the LCD to the assembly.
    Ask FixBot
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 71
All Time: 5,470
