Sony Cyber-shot DSC-T1 Flash Replacement
  1. Sony Cyber-shot DSC-T1 Flash Replacement, Battery: step 1, image 1 of 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
    Ask FixBot
  2. Sony Cyber-shot DSC-T1 Flash Replacement: step 2, image 1 of 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
    Ask FixBot
  3. Sony Cyber-shot DSC-T1 Flash Replacement, Flash: step 3, image 1 of 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: step 3, image 2 of 3 Sony Cyber-shot DSC-T1 Flash Replacement, Flash: step 3, image 3 of 3
    • Locate and remove the 3mm screws on the top and sides of the camera with the size 00 screwdriver.
    Ask FixBot
  4. Sony Cyber-shot DSC-T1 Flash Replacement: step 4, image 1 of 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
    Ask FixBot
  5. Sony Cyber-shot DSC-T1 Flash Replacement: step 5, image 1 of 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it. (If difficult, your fingernail can also be used)
    Ask FixBot
  6. Sony Cyber-shot DSC-T1 Flash Replacement: step 6, image 1 of 1
    • After releasing the clips, pull out black lens box.
    Ask FixBot
  7. Sony Cyber-shot DSC-T1 Flash Replacement: step 7, image 1 of 2 Sony Cyber-shot DSC-T1 Flash Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to flip the clip.
    Ask FixBot
  8. Sony Cyber-shot DSC-T1 Flash Replacement: step 8, image 1 of 2 Sony Cyber-shot DSC-T1 Flash Replacement: step 8, image 2 of 2
    • Grab the white part and slide it to the right until it clicks.
    • This may require some force.
    • Pull out the flash.
    Ask FixBot
Paul Elrich
48 Reputation
2 Guides authored
Cal Poly, Team 7-35, Maness Spring 2012 Member of Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,253
